Originally posted by doylna
View Post
ENG: Replace the Vehicle Speed Sensor (VSS)
Originally posted by minoreparations View PostYou're trying to weasel your way from the point that I made. But this is not the place to discuss that. And the reason why I've never made a diy is because I can't stop every 30 seconds to take a picture. If I had a photographer with me at all times I'd be glad to make a diy just for you.
Originally posted by doylna View PostWell my e-penis is definitely smaller than yours now. You win this thread. I prostrate myself to you.
Seriously dude...
Whatever it is... It was clearly emphasized, so don`t be a dick. Someone here was just trying to help some people on here. Clearly, you don`t have time to take pictures every 30 seconds, but time to be an ass on a forum. Not time well spent either I would say.
P.S
I got the VSS from Dr. Auto Parts on eBay. I finally got a refund.
Originally posted by k-mart View PostThat's good to know, but a step past that...
Are auto/manual VSS's interchangable?? As far as the adaptability of the 3P connector and the drive link??
TIA!!!
I have to assume that the manual and automatic VSSs are the same, as I didn't specify manual vs automatic when I bought mine, and it worked fine in my manual. Given that there are far more automatics than manuals, I'd guess that the more commonly produced version would be automatic, but mine worked anyway...
for some reason my JDM Automatic MP0A VSS didn't want to bolt up to the JDM M2A4 5spd trans. The gear on the Auto VSS was a lot diff. then the gear on the manual VSS, its a lot bigger for one, and doesn't go in the 5spd's I found out. Plus, the bracket is a bit short, so the sensor can't be secured properly. Anyone come across this when doing a 5spd swap?
member's ride thread
91 Accord SE 176k
This is a godsend2013 Honda Fit Sport Alabaster Silver Metallic GE8
2013 Accord Sport Modern Steel Metallic CR2
CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
Although an older thread, I'm throwing in my two cents!!
I too purchased the e-bay special VSS about three months ago (after a few months of putting it off). Local stores all wanted $90, to which I said .
So I got my ebay VSS, installed it,.. Then went for a test drive. At first it seamed as though all was great. Until I noticed my tach!! (to which I'd been using in Lou of my speedo for a few months) It was saying I was doing 40, while the speedo says I'm doing 30!! Yet after 20-30 min of driving, it comes into accuracy.
I work in electronics and understand what happens here too. The Manufacturer was cheap on parts quality. Using CHEAP resistor/s ended up with a part where resistance changes like a thermistor in varying temps.
My point is just this. If you buy the $20 ebay unit. You MAY want to buy two or three! Just in case 1, 2 fail out of the box.
Or spend the $90 on a decent part! It's A LOT cheaper then the speeding ticket you'll get!
I went to the jy and came up on two vss I cleaned them up and put the one that was oem on my wagon, and I now can tell how fast im going2013 Honda Fit Sport Alabaster Silver Metallic GE8
Originally posted by CBsevenTUNER View PostCan a faulty VSS adversely affect your cars MPG? Ever since my speedo went whacky, so has my MPG. I don't seem to be getting my usual 28-30mpg. Is this a real concern or am i just imagining things?
Originally posted by Hostile View PostWhen mine wasnt working, my mile counter wasnt working eighther.
I dunno if im right in saying this, but i think the faulty VSS may be messing with my gas mileage. Maybe through the ECU by way of the map being adjusted for throttle position and speed.
Im not sure. If anyone has had experience with this, i'd love to hear it....
maybe i should make a thread if this discussion has any merit.
