Old 08-09-2010, 10:54 PM   #1
acefighter028
CB7tuner Member
acefighter028 is cool... so far.
Send a message via MSN to acefighter028 Send a message via Yahoo to acefighter028
help please. Rust and structural integrity question.
ok, here's the deal. I've scoped out a 1993 CB7. It's all great except the throwout bearing may need replaced. But the thing that bothers me alot is the rust. It looks ok from the outside but it runs from the rear of the quarter panel all the way under the wheel well and through the door jam about an inch and a half. I'm wondering if it's repareable or if it's terminal. Please help me. I have no pictures at the moment.
It's in the performance section because I'm afraid it compromises structural integrity.
Here is the link to the car and picks http://www.rosedalecars.com/110544/1...da_Accord.html you have no idea how much i want this XD
Last edited by acefighter028; 08-10-2010 at 06:07 PM. Reason: Changing title, adding link
acefighter028 is offline   Reply With Quote
Old 08-09-2010, 11:19 PM   #2
fleetw00d
Contributing Member
If it looks like this:
or this
do your best to find a rust free car. They are out there (2 1/2 of mine are). Rust repair, particularly if it extends all the way around the wheel well and into the rocker panel, can be very expensive if done correctly (particularly if you're paying someone else to do it).
I am going to attempt to repair the one pictured above (for reasons I won't go into, I have to keep this car until I die). Got rust free quarter sections from another car and picked up a spot welder relatively cheap. When I really get into it, I'll start a thread. Right now, most of the outer skin on the right side is gone, just a small section along the top that meets the trunk lid and it still doesn't seem to bend much.
You might get more lookers if the title of your post was a bit more descriptive.
__________________
90 LX 4dr 5 spd 380,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
92 EX coupe auto 193,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
07 Element EX AWD 183,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
INVENTORY REDUCTION! LOTS of CB7 parts for sale or FREE http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 08-09-2010, 11:50 PM   #3
acefighter028
CB7tuner Member
Quote:
or this
Thanks you much. your help is appreciated . The asking price is $2950 but i wont pay more than $2500. I know its expensive but i have the money. and about the pics, the one im looking at isnt as bad.
Old 08-09-2010, 11:58 PM   #4
fleetw00d
Contributing Member
Mine didn't look this bad until I removed the bumper and the rocker covers and started picking at and removing all loose rust. If it has any at all, it will continue to spread unless it is cut out and replaced and treated. How many miles on the one you're looking at? I've seen two ads for rust free cars in the Cincy area (less than 135,000) for $2000 or less. I haven't gotten to look at them in person yet, but the pictures looked OK. IMHO, resist the urge to buy and wait for a rust free vehicle.
__________________
Old 08-10-2010, 12:40 AM   #5
khoanguyen
CB7tuner Member
khoanguyen is cool... so far.
That looks so nasty.
khoanguyen is offline   Reply With Quote
Old 08-10-2010, 01:04 AM   #6
acefighter028
CB7tuner Member
I need a car now and i fell in love with this one, but i see what you mean and will think about it. it has 150,000 miles. I will post the link to the site if it works later :/
Old 08-10-2010, 01:09 AM   #7
batever
CB7tuner Member
batever is cool... so far.
I found a great old timer guy who repaired rust almost as bad as that, including new structural steel on the side rails, for $400 per side. I knew I had the right guy when he pointed to some relatively cosmetic rust on the rear quarter panel and said "do you want to leave that or do you want me to fix it?" like it was a normal option some of his customers took.
However, guys like that are a rarity. One other body guy actually ran out of his shop waving his hands and saying "I'm NOT going to work on that!" when I drove up to his shop and said that it would cost "thousands" to do both sides and I should just patch it up with foam and bondo to pass inspection and start saving for a newer car.
Look for a place that does frame welding, they are used to dealing with stuff like this.
That being said, rust free is better than not rust free. Doing that job right entails cutting out the bad rocker panel section, media blasting the metal, welding new steel in, rust treating and painting it, along with the usual replacement of the wheel well (fiberglassing it in probably) and the rear quarter panel section.
batever is offline   Reply With Quote
Tags
rust , structural integrity
