Old 05-05-2012, 02:34 PM   #1
IE_CB7_01
IE_CB7_01 is cool... so far.
Will the Tanabe Sway Bars fit a 90 to 93
After doing some research on sway bars, I saw and really liked the "Tanabe" sway bars, but the application chart says that it only fit's the 94 to 97 Accords?, where all other sway bar manufacturers fit 90 to 97 ?
I contacted Tanabe, and there response on my question was they were not sure if it fits the 90 to 93 CB7 application, as it was designed for the 94 to 97 accords?
Doe's anyone else have info on whether or not these sway bars will fit the CB7?
http://www.tanabe-usa.com/stabilizer.asp
Thanks...
IE_CB7_01 is offline   Reply With Quote
Old 05-05-2012, 02:41 PM   #2
deevergote
Don't call me dude.
If all other bars are interchangeable between 90-97, then these should be as well.
They may be designed for the specific geometry of the 5th gen, which is why they're 94-97 only... most suspension components are designed with 5th gens in mind, and just passed down to us as an afterthought, sadly. The differences are slight in most cases, and we rarely notice them.
Anyway, they SHOULD fit.
Is there a particular reason you're choosing Tanabe over Suspension Techniques or Progress?
Old 05-05-2012, 04:10 PM   #3
IE_CB7_01
Hey Deev, Thanks for the prompt response, they just seem to be really well made, the thick diameter and hollow tubing and the forging process which I read somewhere that these go through is much better than most, outside of that I am open to any high quality Sway bar set.
accord , cb7 , handling , suspension , sway bars
