Cold Air Intake Options.....
    Now I'm curious, (this is probs gonna sounds insane) fabricating a system where there was two filters that lead to either side of the fenders do anything? I guess a dual CAI
      It would be interesting, but ultimately pointless. I don't imagine it would do anything for power gains. A short ram is the best option unless you don't want a filter in the bay.
        A couple years ago I came up with plans for a pressurized CAI that would feed from the passenger side of the upper grill (the one with the "H" in it). I wasn't planning on keep A/C at that time and had the dimensions already measured out for a custom radiator. Ducting is easy enough to come by and all you'd need is a enclosure for the filter (or you could just duct it at the filter but you'd gain more while moving if it was pressurized).
          The issue with that is that the front of the cb is fairly aerodynamic. Unless you can ensure such a duct would be an effective scoop, it'll essentially be in a vacuum. If you can get a genuine ram air effect, it would indeed be useful at speed.
            Originally posted by sonikaccord View Post
            The stock intake is cold air. It pulls air from inside the fender.
            The intakes are actually right behind the right headlight in front of the battery. If you want it to pull from "inside" the fender, you would have to remove the intake resonator.
              Given the number of bugs large and small I clean off the upper part of my radiator I'm sure that enough air is pulled/forced through the upper grill. Anything directly in the front of the car is going to be in a high pressure area so introducing an area of vacuum there (in the form of an intake pulling air) is going to be effective. I never tried it but the theory is sound.
                Maybe a hood vent going into a flipped LS style intake. Like the Corvette ones.
                  just cut a a hole in the hood and have the cone filter stick out
                    Honestly haha
                    But jokes aside, unless you're cranking crazy power, a hole in the hood is just gonna look plain silly
