Go Back   CB7Tuner Forums > Parts & Performance > Audio/Electronics
Old 06-17-2011, 06:16 PM   #1
JezzWolf
JezzWolf is cool... so far.
Well I almost got it removed all the parts... But one. The antenna at the bottom has a locking sleeve that keeps it from pushing the innards out. Well that is still left behind from the old one in the shaft after the antenna motor. So the new one wont go in. I need to remove the old sleeve. Any help?
Figured I'd post pictures. I'll help you, help me.
This is the whole thing;
This is the part that I think is stuck;
This is the antenna shaft and the stuck part;
Oops Sorry about the giant pictures.
JezzWolf is offline   Reply With Quote
Old 06-17-2011, 08:46 PM   #2
Night Wolf
Night Wolf seems to have made some friends!
Send a message via AIM to Night Wolf
use a stuck bolt remover drill bit. its got a reverse tread thatll grab & pull it out
93 Accord LX Sedan (sold)-01 Civic LX Sedan (sold)-93 Accord EX Wagon (totaled)
93 Accord SE Sedan (sold)-95 Accord LX Wagon (CURRENT)-92 Accord EX Sedan (sold)
93 Accord SE Coupe (sold)-97 Accord SiR Wagon (CURRENT)-05 Impreza WRX Sedan-(CURRENT)
Night Wolf is offline   Reply With Quote
Old 06-18-2011, 10:25 AM   #3
Tippey764
Silver Member
that thing is a pain in the ass
No a stuck bolt remover won't get it out because its technically a nut
Op that little silver topper ( shown below in gold ) did not come off like that did it? I bet the top broke apart from the threads didn't it?'
Also that is a cheap shitty ebay power antenna mast and you will not be happy with it. I bought one and had aton of trouble getting it in. That sleeve you pointed out is different on an OEM antenna mast. I'd return that and get an OEM honda mast
Tippey764 is offline   Reply With Quote
Old 06-18-2011, 12:20 PM   #4
JezzWolf
So I guess I found my problem... Paul helped me remove it and he twisted off the top part of the bolt. Maybe I'll have to check out a walk through and see what parts I have that I should be missing.
I did have a Honda antenna bolt in there it was just corroded. And I think that is the other layer of metal in there. Because the top came off but not the stem.
Well I got the locking tube out.
And then this happened;
So Any idea where I can get a new antenna shaft?
Old 06-18-2011, 12:26 PM   #5
Accrdwgnguy
I would guess Honda, but its not cheap.
Universal replacement power antenna?
Old 06-18-2011, 12:30 PM   #6
JezzWolf
Looks like the plan.
Old 06-18-2011, 10:39 PM   #7
fleetw00d
Unfortunately, you won't be able to get just that outer sleeve from Honda; you can only get a replacement mast or the whole assembly. I used to rebuild these, but couldn't make much of a profit. Corrosion and failure of that tube was pretty typical. I used to buy every antenna I could pull from junkyards for spare parts. I bought masts from Bridgewood Motorsports, never had an issue. The key is to not just attempt to replace the mast; I always took the opportunity to disassemble the whole thing, clean it out, and relubricate it when assembling. The power antennas still work on all four of my Accords.
90 LX 4dr 5 spd 367,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 249,000 MRT:http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 168,000 - MRT:http://www.cb7tuner.com/vbb/showthread.php?t=205114
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583
Old 06-19-2011, 02:28 AM   #8
coupes
coupes is cool... so far.
http://www.bkhondaparts.com/billkay/...hidIrno=%7C049
coupes is offline   Reply With Quote
Old 06-20-2011, 11:21 AM   #9
DarkHusk11
DarkHusk11 is cool... so far.
Shave it and put an internal antenna
1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
Originally Posted by keepinitclean View Post
I give it 2 weeks before you sell it.
DarkHusk11 is offline   Reply With Quote
Old 06-29-2011, 11:42 PM   #10
JezzWolf
Thanks guyz! I ended up getting one off ebay.
Old 06-30-2011, 01:46 AM   #11
SilverShadow
SilverShadow is cool... so far.
Send a message via AIM to SilverShadow Send a message via Yahoo to SilverShadow
antenna
Given to me by Wilson ..AKA Ikayto
http://locustom.com/shark2_kit.htm
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
SilverShadow is offline   Reply With Quote
Old 07-11-2011, 06:05 AM   #12
JezzWolf
Thanks man. I ended up getting a universal one off ebay. It is not the most dazzling thing but it works great!
Old 03-10-2012, 12:28 PM   #13
fleetw00d
Contrary to my previous post in this thread, Honda does now offer the aluminum tube that is shown broken off earlier in this thread, approximately $27 through Majestic. The trick is getting the bottom of the tube out of the motor housing. I've used a 7/8 spade bit to get it to rotate, then spin it out (take your time).
Old 10-08-2017, 06:50 PM   #14
wtfisafleek
The main aluminum tube or the short 3-inch bit with the clip were not my problem. My problem was getting the plastic ribbon back inside it the housing. I guess with the way it wants to naturally curve, mine didn't want to go back in the hole no matter how I twisted or how much pressure I used.
I ended up using a length of tubing to put down in the housing to limit how much the ribbon could curve and keep itself from going in the hole. Once I got it to feed through, I just pulled the length of hose out and sliced it down the middle to take it off.
Old 02-13-2018, 09:25 PM   #15
fleetw00d
Well, not available from Honda anymore, but the aluminum tube is available from Bridgewood Motorsports:
http://www.antennamastsrus.com/Honda...01990-1993.htm
They also carry aftermarket power antennas, manual and fixed antennas.
