Old 02-24-2017, 09:16 AM   #1
deevergote
Don't call me dude.
Rattling coilovers?
I noticed this in my Miata, but I've noticed it in every car I've ever been in that was equipped with coilovers, including CB7s.
My coilovers rattle. It's annoying, and really reduces my confidence in them. I assume that since my setup is fairly new and decent (Flyin Miata... wouldn't have been my choice, but I'm not fearing for my life on them) and it was professionally set up that it's not likely due to materials or settings. Is this just a thing that adjustable coilovers do? I've never had anything but OEM or quality aftermarket springs and shocks/struts on all my cars in the past.
I'm seriously considering yanking these adjustables for some good static stuff!
BUY MY STUFF!!!
NEW PRICES ADDED 09/24/2016
AEM TruTime cam gears (H22A), DSM 450cc injectors, Eaton M45 superchrager
Old 02-24-2017, 11:11 AM   #2
F22Chris
F22Chris is cool... so far.
That doesn't sound right. I'd check it out. Make sure everything is tight, and there's no rubbing. Mine never rattled, that's weird.
Old 02-26-2017, 11:51 AM   #3
deevergote
Don't call me dude.
Weird. Every car I've ever been in with coilovers made a similar rattle. I'll poke around once it gets warmer out to make sure everything is tight, though the guy I got the car from was probably the most anal, meticulous person I've ever met!
I should probably yank them and sell them in favor of some good mild springs and quality shocks (bilsteins are the plan.) Never much cared for coilovers anyway.
BUY MY STUFF!!!
Old 02-26-2017, 01:09 PM   #4
Corweena
Corweena is cool... so far.
Can you explain the rattle? Is it under load at turns, over bumps, going in/out of driveways?
Looking at Flyin Miata's design, its a traditional coilover with tender springs to keep the main springs in place at full droop. Have you jacked the car up and tested if there is any movement of the springs at full droop?
I've honestly never had any rattling with my Koni/GCs, at least that is directly associated with the suspension. What does happen though is when you put stiffer suspension on an older car is that other things start to loosen. Any time i hit a bump on the freeway (or any kind of abrupt change in pavement), is that I'll hear noises and rattling from behind the dash, and somewhere in the trunk. Its just what happens when you crank up the shock's compression damping after 20 years.
As long as the suspension is in there properly, with no extra movement, you should be fine. It could even be a number of other suspension parts that are making the noise too. Its not like its a blown strut clunking over every bump, or the spring coils binding on driveways.
I honestly don't know if going to a spring/shock setup would for sure eliminate the issue. It may definitely lessen it, since its probably a softer setup. But its still not stock, so it may still somewhat be there.
Corweena is offline   Reply With Quote
Old 02-26-2017, 01:16 PM   #5
deevergote
Don't call me dude.
I usually only notice it when going over rough roads (lots of those in NJ!) It sounds like the spring is loose and moving around.
I haven't jacked it up to test, but I'll definitely do that.
I've actually contemplated going back to stock as well. I don't know if I'll be racing the car, so it's likely got plenty of sportiness for street use in stock form. The guy I bought it from used it for autocross, so he made good use of the upgraded suspension (it's a shame I outweigh him by 50+ lbs... he had it professionally set up with him in the car.)
BUY MY STUFF!!!
Old 02-26-2017, 06:47 PM   #6
Crankshaft
Crankshaft is cool... so far.
Do they have the rubber insulators?
Old 02-26-2017, 08:53 PM   #7
Vermonter
Vermonter is cool... so far.
Are they preloaded properly?
I've never had any problems with rattling. The coilover company should provide specific preload instructions. If you remove a coilover and you can rotate the spring by hand on the sleeve, then it's probably not preloaded correctly and when you hit a bump, it's decompressing the suspension and allowing the coil to rattle around on the sleeve.
Check it out.
CC2 Vigor.
Vermonter is offline   Reply With Quote
Old 02-27-2017, 01:08 AM   #8
Corweena
Yeah its probably best to check it out. See if anything is rattling at all. If I had to guess, check the isolators between the spring and top hat, as well as the ones between the main springs and tender springs. If its on rough roads, I doubt its the springs that are unseating or anything, since they never extended fully. It would be an issue if they were making noise angling in and out of driveways, where one wheel will extend. This is an issue with Koni/GC if you order too short of springs. But for rough roads, it could very well be just because the setup is much stiffer than OEM. Just a small price to pay.
Check it out.
Flyin Miata coilovers don't have a set preload. They are a traditional style coilover and adjust from the lower spring perch. They utilize tender springs to take up the slack of the main springs when fully extended, and the weight of the car is the preload. Its not like F&F KSport, and all the other brands out there that adjust from the lower mount now.
Old 02-14-2018, 01:33 PM   #9
Bunta
Bunta is cool... so far.
I know this thread is a bit old but just in case anyone comes across this issue in the future I was advised by a technician at BC racing that after a few weeks on new coilovers to recheck the preload. The springs do settle and that loosens the preload. This would make it seem as though even relatively new coilovers had a defect.
Old 02-14-2018, 04:36 PM   #10
deevergote
Don't call me dude.
I still haven’t fixed it, so I’ll give that a shot once it gets a bit warmer out. Thanks!
BUY MY STUFF!!!
