not bad, should of put all the comparisons apart so it wouldnt be as confusing you kno, just put the the DIY for the parts your using and every other bit of info as side note....but overall good
SUSP : 5 lug conversion 6th Gen Accord
Originally posted by rezist09 View Postthius looks cheap to do next thing ima do thanks
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Just to make sure EVERYTHING has been stated and confirmed. The tow changes due to the tie rods connecting place being closer to the hub than the original cb. I did not notice it till the other day. I will give deatils on axles then as well. I have all 3 to choose from, cb, lude h22 and f23. I have been working too much with my new job to get anything done.Last edited by da9b16; 12-03-2009, 01:15 AM.WAGONS
94 ce1- f22b DOHC auto swap, ROH 11.1" 99 cl brakes, rear disk swap, dual plenums, aem cai, tein ss, OEM stanley one piecers, OEM stanley yellow fogs, OEM 96 Oddy roof rack, Yakima basketcase, some wheels, some tires.... etc.
sense were using the crv's rear drum can the hub from the crv be used as well . imma look for the 00 x at the yard tomorrow . imma read this again , an lil lost on the tl info.
good write up none the less . thank you for other options on this mod___________________________________
I like the "suck me slowly" part. Thats my favorite.
Originally posted by ncoutlaw View Postsense were using the crv's rear drum can the hub from the crv be used as well . imma look for the 00 x at the yard tomorrow . imma read this again , an lil lost on the tl info.
good write up none the less . thank you for other options on this modWAGONS
Originally posted by civic_90_08 View PostBump this thread.
Im in for info about the axles and the rear end parts.
Im disc in the rear...just need to know what parts are needed for the rear end.
The only ONLY parts you can use are the outter drum.... not the whole assembly.....
The 97-99 TL 5 lug CAN be used but you have the change the hub to the LUDE hub because the TL hub sits out further creating an offset if you will that sticks out almost 1" from the fender... anything else?WAGONS
Originally posted by da9b16 View PostLet me re- phrase what I have already stated.... the CRV rear end trailing arms will work on ONLY civic and Integras since they are similar chassis. The CRV rear end AWD will NOT work on accord as they have completely DIFFERENT rear ends....
I ♥/Miss My Coupe
Originally posted by da9b16 View Postwhat do you mean any more info???
i want to do the swap but will stay stock motor/trans for a while
Yes indeed you can use the accord axles...... Since my h22 is using accord axles and they have the same spline count as these do.
I want to say this again for clarity..... you will have to have the tow corrected once this is done.... since the mounting point is closer to the hub. I did a redneck alignment on mine last night so that I could drive it.....WAGONS
Originally posted by da9b16 View PostYes indeed you can use the accord axles...... Since my h22 is using accord axles and they have the same spline count as these do.
