oil in radiator-HELP
    Today I check oil and there is oil in the radiator.
    There is oil in radiator reservoir.
    Is there a possible way that it leak from engine?
    what could it be?
    could be a head gasket
    http://www.cb7tuner.com/vbb/showthre...=1#post1823428
    My Custom BB6 Dash Swap Thread
      head gasket? how do I know its bad?
        drain the oil from your engine to see if it's like chocolate milk.
          haha.
          Tell you guys what, I already have coolant flush first time I brought it.
          Don't know why it come back.
            Head gasket
            1996 Honda Civic LX 2009-2012
            2012 Kia Optima LX 2012-2013
              Yep, sounds like your head gasket is shot. And like they've said, when you drain your oil, if it looks like chocolate milk, it's the head gasket. A compression test might also let ya know if it's the head gasket.
                damn, is it a lot to replace the head gasket?
                  depends on who does the work, probably no more than 250 bucks in parts if you do it yourself but probably ~1000+ if done by a dealership
                  if you're tight on money, i'd probably see if there are any local members that could help, just promise them food and drinks and throw a little money there way
                    wow that much!!
                      well those prices might be extreme but theres actually a lot invovled.
                        On a side note, if you decide to tackle this, you might check out the condition of the timing belt, if it looks worn, I'd change that and the water pump.
                          this is crazy
                          will this do it?
                          http://cgi.ebay.com/ebaymotors/90-93...Q5fAccessories
                            i wouldn't be too cheap when it comes to critical parts like the water pump, timing belt and the head gasket. Honda Genuine parts are what i'd use BUT, if this is your only car and money is tight, "Fel pro" would be the the cheapest i'd get without sacraficing too much on quality.
                              Yes I understand but I'm just asking;
                              Is that what I have to get or something like that
