VHT: Red Nite Shades
    Has anyone tried this for red DIY tail lights ? http://www.vhtpaint.com/products/niteshadesred/
    Instagram: robkhaira
    MRT: 1991 EX-R: http://www.cb7tuner.com/vbb/showthre...52#post3273952
    Haven't used the VHT stuff yet, but I always use Duplicolor Metalcast red when doing tail lights. Pretty much the exact same stuff the VHT paint is.
      VHT sucks.
      wat?
        Why?
        I use many of their products with great results.
          I've seen people use the black VHT, and it looked awesome. Just curious as if its worth it or not as the red one is a new product ( thats what the guy at the shop told me )
            My all clear tail lights are DIY'd with VHT Red Nite shade. Did it because i liked the Red/Clear look and Advance had it on sale. Been like that for a couple years now, i need to redo them since one side is a little faded compared to the other side.
            heres a picture.
            Turbo Setup: 100%
              I've used the black VHT and I polished it and it shined brilliantly!
              I've wondered about how the red would look.. I've been meaning to get a can and try it out. I'm sure you can get the same results.
                Well this is what all red looks like with Duplicolor Metalcast. VHT will look no different. I sprayed the whole lens, not just the amber section.
                  So I'm looking at this: http://www.duplicolor.com/products/metalCast/
                  You've used VHT before correct? Would you say they're on about the same level of transparency? For some reason I just feel like the Duplicolor would be a little less transparent?
                    Yes that's the Metalcast I use. I have not used red VHT. I have used VHT Niteshades, but since I hate blacked out lights, I don't use it anymore, and that stuff is an absolute pain in the ass to spray without running or getting fish eyes.
                    I've used VHT engine and brake caliper paints in the past. I usually use Duplicolor products when painting.
                      Duplicolor seems to be more of a trusted brand for paint from what i have seen so far. For the transparency it looks like 5spd92's are more "shinier" maybe because they are already red/clear ?
                        His started all clear I believe. The shine is in how well you prep and buff. Not the paint usually..
                          Yea mine are a more glossy, cause i buffed them out a bit. the outer ones look lighter from all the heat put off by the bulbs when stepping on the brake. But i wouldn't worry about fading every week, it took a few years for them to get to that point.
                          Turbo Setup: 100%
                            VHT, Duplicolor Metalcast, Krylon glass paint... Set them all side by side any you probably won't see any difference. Its all the same, they all are transparent paints and give the same ass results. You'll be fine with any of those products.
                              Exactly. It's not comparing apples to oranges. Heck, you can even use transparent candy model paint or stained glass paint and get the same effect.
                              Just easier with the VHT and Duplicolor products because you can spray them on.
