SUSP : Rack and Pinion
    hey guys since here were talking about rack n pinions do any of you guys know why the bolts of my rack n pinion loosen up after a couple of thousand miles??? i mean i tighten them up tight and then later on it loosens up again?? could it be that there oil in the thread of the bolt thats why it loosens up
    CLICK ON SIG FOR MEMBERS RIDE
    "2SIIC"
    Authentic Jerseys for sale
    http://www.cb7tuner.com/vbb/showthread.php?t=188314
      Use Loctite Green or Blue maybe?
      DEVOTE
      FS: Lokuputha's Stuff
        where do they sell that at?? autozone??
        "2SIIC"
          use the red since i think its stronger, and make sure the top is not spinning while tighting it
          Members Ride
            Be careful when using the RED Loctite. If you ever need to remove the screw, you might need to heat it up. But it is more secure. Its your call.
            DEVOTE
              hmmmm guess ill put some of that one after i remove the old rack n pinion and put when i put the new one on ill put that stuff
              "2SIIC"
                DEVOTE
                  hey ramiro how important is it if i dont put back that rubber washer that goes over the rack n pinion in between the frame and the inside of the car ???? how would it affect my steering???
                  "2SIIC"
                    i think thats just to prevent it from vibrating and hitting the frame...so im thinking you should put it on
                    Originally posted by fizzbob7
                    Originally posted by ACC0RD22
                    So. Cal OUTLAWZ
                      Yeah, aren't there some bushings in between that should be replaced? Some parts have a little note "mount bushings not included".
                      Metal Metal and more Metal!!!
                      How much does your wheel/tire combo weigh? Post here!
                      -=Suicide Crew Member #1 (only member so far)=-
                      MY RIDE
                      "I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
                        never mind that question guys cause that car is DONE the bolts that holt the rack in pinion in place broke off so theres no point in fixing tat shit
                        "2SIIC"
                          One thing to add. Make sure that you don't turn the steering wheel excessively while the rack is out. The coil spring in the steering column will break and your horn and cruise control won't work, and your srs light will come on. My daughter got in the car and was playing with the steering wheel while the rack was out!
                          PURCHASED NOVEMBER 1991. THAT'S RIGHT, I'M THE ONE AND ONLY OWNER. BEAT THAT!
                            oh shit are you serious cause thats what happened with my car and my srs light stays on and my horn dont work i wasnt playing with it or anything but when i was doing it the steering wheel would just turn and spin around when i was putting it back together HA fuck it i might be getting me a new one this weekend
                            "2SIIC"
                              Nice write-up, but one question would a 5th gen R/P work in a 4th gen? Is there any other R/P I could use?
                              CB7
                              Removed:A/C, P/S, C/C, ABS, Wires, Battery
                              Added: H22A, South Bend TZ Series Clutch, Fidanza (8lb) Flywheel, Megan 4-1 Headers
                              Waiting For:M2F4 Tranny, NX 50 Shot
                                not sure if the 5th gen will work but i was looking around for another R&P i could use and couldnt find anything...i wanted to decrease the turning radius so i could pop a U easier but i couldnt find anything
                                So. Cal OUTLAWZ
