I've been having these exhaust fumes in my car while I stand still and have my fresh air turned on. When I get moving the fumes don't get in anymore. Been wondering if it could be my flexpipe that's leaking just abit. I also have read couple of posts where exhaust header has been slightly cracked but atleast I don't see smoke coming from there.
Exhaust fumes in cabin?
If its a big enough leak you can park your car over not frozen grass and have a friend rev the engine. You might be able to see the grass blowing underneath the car. Its what I did when my friends car was leaking.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by visualpoet View PostYou shouldn't see smoke from anywhere! lol Could be the flex pipe, could be the header/downpipe joint, could be at the catalytic convertor. Start the car cold, and put your hand carefully near anyplace you suspect a leak to feel for moving air. Be quick, it won't take long for the pipe to heat up.
Originally posted by MrSpeedy View PostSorry, I forgot to post that I cover the tailpipes, so then you should see smoke coming from the exhaust pipe if there's a leak. Atlest i've done that always when I've had a leak. But now it's like there's no leak or maybe a tiny hole somewhere. But I'll just keep searching. Thanks for the tips. We don't have any grass here anymore, only snow. Guess it could work also on that.
Originally posted by wed3k View Postif you have a cast manifold, it could be cracked...check the head to flange and manifold to downpipe gaskets.
If that's the case, get a new header (i got the A4 tubular steel, no cracks! ) and check your firewall for any holes or missing plugs.
Hope that helps!
Originally posted by H22Artman View Postmine does this too.
you can always just switch your air control to recirculating. it gets better air pressure with the fresh air vents closed anyway.MRT
also check your piping around the gass tank under the heat sheld cause if thats leaking it goes stright throught the whole in your car above the gas tank i had that problem made my seats black-----------------------------------------------
''It is what it is, Do what you want''
http://www.cb7tuner.com/vbb/showthread.php?t=167905
Originally posted by H22Artman View PostA/C takes the condensation out of the air. clear windows and no smell.
I NEVER use the recirculate and I NEVER have exhaust smell in my car.
Fix that shit, yo!:
