any one ever attempt an all wheel drive cb7?
all wheel drive..
no. you'd have to adapt the awd running gear from another car and weld in pretty much a whole new undercarriage, more than likely tweaking the chassis beyond usability unless you were extremely careful and were a very good, professional quality fabricator. if you dont modify the stock running gear from another car, you're looking at a $100,000 custom fabricated gear box/transfer case similar to whats in chris rado's AWD TC.
it would be awesome to see, but way more trouble than its worth
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
You'd need to fit an AWD transmission, cut a driveshaft tunnel through the length of the floor, most likely reroute brake and fuel lines, and essentially engineer a brand new rear setup. You'd probably need a modified fuel tank as well.
SERIOUS custom work. If you can't do all the work yourself, you could end up spending tens of thousands of dollars. It'd probably be cheaper to build a full tube frame.
I've thought about it. Probably won't ever attempt it, but the thought has crossed my mind.
i think it can be done.. throw a fuel cell in the trunk, you would have to cut the middle out of the floor and rebuild a new tunnel to run the drive shaft and exhaust, brake lines run down the side under the driver seat so i dont think they would be a problem.. and then you of course would have to fit the cvr motor and trans..
Originally posted by tonytoka1979 View Postyeah but not as fun...
ideas like this are fun on the bench but rarely ever work out in real life.
keep dreaming....
Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
Originally posted by nate'sCB7 View PostI think this idea is an ok one if, like already stated, have the cash to do it.
The only reason, i think, this was brought up is because its become pretty
common with EF Civic guys to use CRV parts and make an AWD Civic.
93 Accord LX Sedan (sold)
Originally posted by Night Wolf View Posthmmm got pics of one?
http://forums.nasioc.com/forums/show....php?t=1894506
Originally posted by tonytoka1979 View Posti think it can be done.. throw a fuel cell in the trunk, you would have to cut the middle out of the floor and rebuild a new tunnel to run the drive shaft and exhaust, brake lines run down the side under the driver seat so i dont think they would be a problem.. and then you of course would have to fit the cvr motor and trans..
