MNdude07 : 1990 Honda Prelude SI
    She's rough on the outside but the motor is in good shape and the interior is very nice. I'll have more pics as I progress through this build. These photos are of the car right when I got it, no cleaning or anything. The car sat undriven about 6 months before purchase.
    Modifications:
    Powertrain
    F22A1 SOHC
    Cylinder Head
    Stock
    Air Induction System
    H23 throttle body with 67mm bore by Maxbore
    H23 plenum portmatched to throttle body by Maxbore
    Blacktrax intake manifold spacer
    F22A6 runners
    EGR ports drilled & tapped, and pipe plugs put in
    Bisimoto heat-shielding intake manifold gasket
    IAB plate removed
    Custom 3" intake with AEM dryflow filter
    FTIV block-off
    EGR valve block-off
    Fuel System
    AEM clear annodized billet fuel rail
    Ignition & Engine Electronics
    PT6 ECU
    NGK Platinum plugs
    NGK spark plug wires
    Exhaust system
    Cosmetics & Miscellaneous
    ESP F22/H22 swap mounts, wrinkle black
    Shaved valve cover
    Neuspeed billet oil cap
    MFactory magnetic oil and transmission drain plugs
    AC deleted
    PS deleted
    CC deleted
    Drivetrain
    M2S4 H23 transmission
    F1 Racing Stage 1 Clutch
    CorSport USA Aluminum Shifter cable bushings
    ChaseBays -3an ss clutch line
    Suspension
    Function & Form Type II Coilovers
    Prothane front lower control arm inner bushings
    Prothane front lower control arm outer bushings
    Prothane front upper control arm bushings
    Energy suspension front sway bar end links
    Energy suspension front sway bar mounting bushings w/zerks
    Moog front lower ball joints
    Moog front upper ball joints
    National front wheel bearings
    Powdercoated front knuckles
    Chassis
    Non 4WS
    Rebuilt steering rack
    Moog inner tie rods
    Off-brand outer tie rods (temporary)
    ESP traction bar with front torque mount, wrinkle black
    Brakes
    Front 11.1" rotor conversion, drilled to 4x100
    Prelude VTEC/Accord V6/ITR front calipers powdercoated wrinkle black
    Techna-Fit SS brake lines, smoke color
    ATE Super Blue racing brake fluid
    Stoptech Street Performance brake pads
    Shoes
    ARP extended wheel studs
    Muteki Super Tuner black open ended spline drive lug nuts
    Drag DR-44 Silver w/machined lip 15x7 +40
    > Dunlop Direzza DZ101 205/50/15
    Electronics
    Stock
    Interior
    Polished gauge cluster trim panel
    Red and white LED dash conversion
    Exterior
    Not clean
    Spoiler delete
    Antenna delete
    Future Plans:
    Drive the shit out of it.
    There are no black and white suspension answers!!!!!!!!!!!
    Not the bright red I was expecting. Them wheel covers gotta go.
    Originally posted by Jarrett
      4WS all day! What are you thinking??
      j/k, looks quite clean. Should be quite the ride
      1992 Accord Wagon (RETIRED)
        I was thinking its more parts to break, makes the car heavier, and the car feels odd. Traditional driving dynamics are out the window.
          Looks good. Not bashing you but what happened to the EF sedan you wanted?
          1990 Accord EX
            You are going to have soooo much fun in that thing!!!!! Nice!!!!
            The CB7 Collector.
            92 LX Coupe F22A1
            2013 Toyota Corolla S
            92 EX Sedan F22A1
              SOOOOOOOOOOOO much better than an EF. Get to work! lol
                It's a newer Si, which is good. This thing has the potential to lay frame, too.
                  nice. always liked how these preludes looked. future plans look perfect. good luck sir.
                    nice! i like these lude's. they look real nice done well
                      She looks good for a 90!
                      Gotta love the pop up headlights!
                        I decided two things about the civic:
                        It is completely ugly and no matter how fast it is, looks like a joke.
                        The weight that the prelude has over the civic can be made up for with its significantly better suspension geometry.
                        I really, really like the prelude's seats too.
                        Thanks for the nice comments everyone! Now i'm off to work on it and clean it more to get it flog...i mean driveable.
                          As of now the car is in my grandpa's garage, and tomorrow I will begin disassembly and making this hooptie into something. I'll try to get some interior photos now that I've cleaned the inside some...its not perfect yet though.
                            This Lude's look amazing, of the best looking IMO.
                            Just be careful with the B21, it's supposed to burn oil easy due to the FRM cylinders buring out the rings from what I've heard.
                            Originally posted by Wikipedia
                            The B21A1 was basically a re-worked B20A5 with an increase in bore to 83 mm (3.3 in). The external block dimensions had to stay identical (although there was increased external strengthening and webbing on the B21) to the B20A5 block so Honda called upon Saffil to create a thin but strong cylinder liner called FRM (fiber reinforced metal) which basically consisted of a carbon fiber matrix, aluminum alloy, and aluminum oxide to make a very strong cylinder sleeve. The sleeve is so strong, in fact, that it wears out the piston rings causing low compression numbers, severe smoking, and high oil usage. It is possible in many situations to merely replace the worn rings in order to revive the motor's former output. Many machine shops will not attempt to re-hone or re-bore the FRM sleeves, as this type of sleeve will de-laminate during machining operations.
                            Current:
                            2007 Acura TL Type-S 6MT KBP
                            Past:
                            1992 Honda Accord EX-R Sedan - RIP
                            1991 Honda Accord EX-R Wagon - RIP 10/14/2010
                            Words change lives. You just got to choose the right ones.
                            Instagram: @CB7Nub
                            Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
                              Thanks man! And yeah, it does burn some oil...that's ok though. That motor won't be staying in the car. I'll be swapping in the f22a1 from my wrecked cb7 and doing an all motor build with it.
