Intake gasket set question: f22a4 vs a6
    I ordered this kit:
    Fel Pro ms94781
    http://www.amazon.com/Fel-Pro-MS9478.../dp/B000C2ED04
    The box claims it's good for the 2.2 F22A4 from 90-91 and the 2.3L H23a1 92-96.
    Will it be ok on my 1993 EX F22A6?
    It sure looks right.
    It's an error on the box, I've seen it many times before. But yes, this will fit your A6.
      Since they're not returnable opened, I figured I wouldn't throw away 12 bucks if I didn't need to.
      I can confirm after opening that this kit fits my A6. And it's about the same cost (less actually) than just the main intake to head gasket from Fel Pro alone.
      Thanks
        This is from several years ago.
          for future searchers yes, that's the box i got.
          seems oddly specific about what it's made to fit, i'm no expert but it seems like it would fit all f22a4 and a6 from 90-93, yeah?
          the f22a1 has the different plenum gasket, i believe just one gasket, only 4 holes in it, because it doesn't have the IAB setup.
            This kit will NOT fit an A1 or A4.
              next time use majestic honda for part numbers then plug them into ebay and youll find some really good discounts on oem stuff. i got both IAB gaskets for 7 bucks! just a lil fyi if you got the time.
                right, my mistake the a4 doesn't have the iab either. the box is totally wrong!
