Best cheap suspension?
    Hey all, I can't post under "suspension" maybe because i'm a fairly new member? Anyways, my suspension is stock and the front driver side is blown (squeaks over bumps) what's a fairly good suspension that isn't going to break my bank? I don't want stock, I'd rather something that can help me take corners and increase stability. I'm going to need a front strut bar as well but not too sure which are good and which are the equivalent of a shower rod. I know it's a lot to ask but any suggestions would be good, i'm working a full time job but don't make a whole lot of money hopefully someone else here who can relate, I love my CB with all my heart and want to make her shine again.
    Unfortunately suspension is one of those areas that you can't cheap out in. Even a lower end setup is still going to run you $500. Even then you likely won't be as low as you want. It's not beyond you to look around to see what prices are. Just stay away from the no-name crap and you'll be okay with your stated goals.
      here we go again... lol
      you should start your reading here http://www.cb7tuner.com/vbb/showthread.php?t=178582
      it will give you a good idea of the basics
      MRT http://www.cb7tuner.com/vbb/showthread.php?t=188701
        This is a good place for me to start, i appreciate it my friend
          no problem its good reading
            Don't forget to get an alignment. ].
            MY MRT
            http://www.cb7tuner.com/vbb/showthread.php?t=178936
              Im with Jarrett on this completely. But...When you can't afford to go all out on your suspension, just wait & stack your chips (money, not Pringles, dammit) and get the better stuff.
              "There are only two types of people in this world... Those who run & win, and those who sit at the sidelines & watch the winners pass them by."
              My YouTube Channel! - There's more videos here!
              Check 'em out, hit LIKE, or even better, stay updated with more vids when you SUBSCRIBE, including vids of my JDM H23A swap!
                the squeaking is most likely coming from your worn upper strut mount bushings. These can be had for about 2 bucks a bushing from Honda.
                You'll need a total of 8 bushings for front/rear. I think the rears are different than the fronts.
                My DD's suspension used to creak over all types of bumps because the rubber was hard and petrified being over 20 yrs old.
                member's ride thread
                91 Accord SE 176k
                  this is about as cheap as i would go . http://performance.importrp.com/toki...k/g-50654.aspx
                  this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
                  Car safety checks
                  Fluid Capacities
                    on that same website, you can get Koni STR-T's all around (a much better shock than Tokico's) for $273 and H&R Race or sport springs for $240. That setup will lower it 2" (for the races) or 1.5-1.75" (for the sports) for a total of $513 plus shipping.
                    for $100 more, you can grab a set of ground control coilover sleeves and get height adjustability with quality springs.
                    To take corners better, you are going to want at least an upgraded rear sway bar. The progress is the stiffest one you can get for our chassis and it eliminates most if not all understeer and body roll.
                    For a tower bar, I would look up the "Sprint" strut tower bar on ebay, they are about $45 and are the same solid-mount design as the now-discontinued Neuspeed bar.
                      don't forget your local junk yard i picked my ebiach proline springs with kyb struts sitting inside them for $75 for all for corners the struts lasted a little over a year but i still have a good set of springs . they are getting replaced with BWR coil overs after we swap out the caps i pulled out of a donor prelude i picked up off of craigslist which is another good place too look for suspension for a couple hundred dollars . it helps alot too know your interchange list when going too the junk yard or using craigslist . i got my original suspension off a newer Acura cl and the newer is coming from the prelude. use your legs wheels and fingers too get the best prices on parts don't just wait on a delivery. i know your pain married with children working full time trying too keep your beloved cb running
                      CB7TUNER.com
                        thats not a good idea ( my personnel opinion ) . the matching of spring's and struts should be left to the experts . OP don't just through miss matched parts from a junk yard on your car . if you do go to a junk yard get oem parts that's are good not mixed . getting mixed part's like that is dangerous and can hurt or kill you and others.
                        Car safety checks
                        Fluid Capacities
                          it was a matched set i didn't mix n match parts nor did i tell him too but isn't doing any kind of swap be it suspension or motor or brake mismatching factory parts
                          CB7TUNER.com
                            ebiach proline springs with kyb struts do not go together . kyb is a stock replacement strut . ebiach i don't even think they support our cars weight may be a civic or a da .
                            Car safety checks
                            Fluid Capacities
                              i clearly stated they came off a acura cl which is close enough too a accord and is one of the cars used on this forum for brake swaps so your saying the cl is good enough too stop us but not good enough too hold us up ?
                              CB7TUNER.com
