91 accord daytime running lights stay on with key out
    Got home late yesterday and didnt have time to check. Today ill be giving fuse #23 a pull and. See what happens. If anyone has any other ideas feel free to chime in. Or if you know which wire i can throw a switch on and atleast be able to turn off the lights when i park instead of having to disconnect the battery after every stop i do for work which is one every 10-20 minutes.
      I agree with you that it's most likely the switch. This will tell us where along the line it's broken and verify that it's the switch.
        The headlight/combo switch right? Anyone know how to check it? Im in the middle of moving so i havent had much chance to check the fuse. But i have a multimeter and can check anything electrical with the right guidance
          Hit that junkyard and get the switch then swap em out but before you do that always disconnect the battery before you disconnect and reconnect anything just for good measure. It shouldn't cost much just a few bucks like 20 bucks or so.
            Following. I'm having the same problem. I pulled the small light fuse under the hood. Lights are still on.
              Fuse 23?
