can i seafoam my car?
    Can I seafoam my car like this guy did?
    https://www.youtube.com/watch?v=agAWXnT4-EQ
    I'm very broke at the moment and I STILL have done little to no form of maintenance to my car in a long time other than constantly adding more oil.
    The car makes all of maybe 40hp at the moment and I get the feeling maybe the injectors are dirty. There are spots in the throttle where the engine stutters if you press it at sort of a medium level.
    If this seafoaming can just keep it alive longer that would be great. I don't need the car to go fast or have more hp I can live with the extreme slowness so long as it'll just keep working. it still starts/idles/shifts/ eventually accelerates just fine , just want it to stay that way.
    Yes you can Seafoam. People do have mixed results from it though
    http://www.cb7tuner.com/vbb/showthre...hlight=seafoam
    Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
    My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
    Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7M
      I was wondering if i can just pour it into the gas tank only , right now the car is almost empty of gas so should I do it now or when it's full?
      I understand that seafoam can dislodge buildups that are actually sealing gaps in the engine that are keeping it from leaking , so I thought maybe just pouring it into only the gas tank would just clean the injectors.
        You can pour it into the gas tank only. It probably recommends putting it in a full tank, but at least half should be ok. Add the Sea Foam first, then add fuel so that it mixes well.
          If you put it in through the intake, clean or replace your plugs afterwards. Everysinglegotdamn time I Seafoam my cars it fouls the plugs. Which makes complete sense due to the fact you dump fluid in the engine in the process. 1/3rd of a can is good for a tank.
