Originally posted by Freshagen
View Post
91 accord h22 swap won't start!
Originally posted by Freshagen View Posti'll most def try that today. but even if my timing was off, wouldn't I still be able to get a spark to bridge from the wire to a grounded bolt??
Originally posted by 92smokeaccord View Postsometimes yes but not all the time..iv had this happen a few times...but dont try to do it to the bolt go right to the sorce and try the - terminal.its the strongest point of a ground....also did u try to even change tthe coil pack?WHEN LIFE PASSES YOU BY...DOWN SHIFT...
You should get spark no matter if your timing is off or not. My point was is it sounds like your getting spark and it's just firing totally wrongs. Before you check your timing at all try to get spark. Go buy a whole NEW DIZZY. And guess what if it works take it back. And then go pull from a junk yard. Because if you get a brand new one you will know it's not the dizzy. After that then start looking everything over. But early warning if you did set your timing wrong and your car happens to start it's just like you were to snap the timing belt and by by engine
Did you remember to jump the two wires off the distributor?
Remember if it's internal coil, you need to use a 30 AMP fuse to bridge them together..or it won't start.Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
Originally posted by k20si View Posti thought you couldnt use the h23 injectors on the cb7...
Originally posted by 10k View Postim in it for the coil pack as well you should check it out could be bad...how about all fuses?? is everything plugged in? double check the main engine connectors to see if they aint loose
Originally posted by andrew22888 View PostYou should get spark no matter if your timing is off or not. My point was is it sounds like your getting spark and it's just firing totally wrongs. Before you check your timing at all try to get spark. Go buy a whole NEW DIZZY. And guess what if it works take it back. And then go pull from a junk yard. Because if you get a brand new one you will know it's not the dizzy. After that then start looking everything over. But early warning if you did set your timing wrong and your car happens to start it's just like you were to snap the timing belt and by by engine
Originally posted by Accrdkid View PostDid you remember to jump the two wires off the distributor?
BASICALLY. I've narrowed the issue down. im getting Power to the IGNITOR, but no the cap n rotor. maybe your onto something accrdkid!
**I WOULD LIKE TO THANK ALL OF YOU GUYS for really stickin with me through this one. It's keeping me from REALLY going Crazy bc of this car. thankyouthankyou cb7tuner famLast edited by Freshagen; 08-05-2011, 02:18 PM.
If you still have the original distributor from the H22 (all JDM H22s are internal coiled). Trace the plug that's on the car it connects to the Accord's original external coil.
If you look at the back of the plug there's a solid yellow and a yellow/black wire that runs to the plug.
They both have female ends inside that plug itself, if you take a 30 AMP fuse and stick it in the plug (basically bridging the two female ends, the car will start.
I re-read your post and it sounds like you mixed up a bunch of parts together using H22 and F22 distributor parts.
Try this method and see if it works.
And check and make sure you have the resistor box hooked up as well. It's located on the driver side fender in the engine bay, looks like a mini heat sink another thing to check : the firing order, if you don't have it hooked up right, it won't start.
:edit:
h23 injectors????!!!! get that motor back to it's original form..and then try what I just suggested..let me know how it works.Last edited by HenRoc; 08-05-2011, 03:26 PM.Henry R
Koni/Neuspeed
Legend FSM
my car is originally an internal coil car, so I beleive the plug your talking about doesn't exist on my car. :/ I'll definately try to get some h22 injectors asap! seen how much stronger the h22 injectors are, the ones I have are far from sufficient.
edit: the resistor is connected as well. does it have to be bolted to a ground?
Originally posted by k20si View Postpretty sure h23 injectors dont use the resistor box and h22 injectors do us it.
I'd agree with accordkid, problem sounds like its in your dizzy, what did you do exactly with your h23 internal coil conversion, or you can pick up a accel or msd external coil and Wire it up real quick to so if you have spark. Unless that ecu went bad sitting in the cabinet, you shouldn't have a problem there. And if it was out of time it should still start, and have spark. And the dizzy can't be out of time unless you removed the keyway(2 pronged piece that slides into the cam) and put it back on backwards. It WILL start and run on h23 injectors but run lean and pull timing.
This is the car the ecu came out of, my girls 90 lx, auto. f23 bottom end h22 head. I used a h23 external coil dizzy and wired in a msd external coil. coil is only like 50 bucks i think
Previous cb7members ride thread
86 Nissan d21 in the workshttp://www.cb7tuner.com/vbb/showthread.php?t=155292
TSM Garage: Honda/Acura, VW/Audi, and Subaru performance and maintenance work.
Contact:Ben Cell: (302) 898-1840
