Anyone with a bisimoto header that's not installed...
    Quick question, can someone please tell me what the flange size is so i can match my head to it when i port the exhaust size. Or is this a custom size that Bisi asks for?
    2013 Ice Cream Cruise!
    VIDEO: 2012 Ice Cream Cruise
    VIDEO: 2012 Ice Cream Cruise part 2
    The single largest cruise in the Midwest!
    August 3 ~ Omaha, NE
    By 1320 Video
    Member's Ride Thread
    I'm sure bisi uses a standard flange for any of the 190-220 whp custom headers he makes. I'll measure mine tonight when I get home if nobody else posts up.
    Make sure you don't make the ports the exact same size as the flange....they need to be a bit smaller....there's an exact science to this that I don't know off the top of my head. You'll also not want to make the ports larger than the openings in the stock exhaust gasket (IMO). I believe the exhaust gasket profile would make a great starting point for porting.
    My Member's Ride Thread
      49.5mm X 37.0mm
        thanks, i'm gunna go take some measurements and see how they compare
        Stock (f22a1) in mm:
        Header 31.2 X 45
        Aftermarket header 31.2 X 42
        Gasket 35 X 48
        Head 30 X 45
        By 1320 Video
          If my information is correct the ports don't really need to be made much larger, only a tiny bit. The flow gains are made by optimizing the shape of the port "necks", something I'm going to let CHR or Bisi do for me.
            hmm, i'll do some more research. i just wanna walk into the machine shop with as much information to the guy as i can get
            By 1320 Video
              Which machine shop?
                Originally posted by D1sclaimer View Post
                Which machine shop?
                probably jut bring it down to Rojam. close and convenient
                By 1320 Video
                  Do some research into the exhaust port anti reversion step. I think that is what beast is referring to when talking about the port opening being smaller than the flange opening.
                  MR Thread
                  GhostAccord 2.4L Blog
                  by Chappy, on Flickr
