Looking for a camshaft
    Looking for a "Bullfrog" camshaft, but I can't find one anywhere. Anyone have the speccs of one, or just knows a camshaft that will make my car idle with a little more rumble? Not wanting to make it a supercar or nothing ridiculous, just wanting a little more rumble at idle.
    91 F22A6
    91 F22A6
    That would be from Gude performance.
    http://web.pdx.edu/~tuff/rethinkRebuild/index.html
      Thanks man, I appreciate it immensely. Been searching forever.
        I didn’t realize Gude was even still in existence! If you’re not terribly concerned with performance, there are other options as well. Gude’s Bullfrog camshafts aren’t terribly inexpensive, and their customer service is so bad that it’s legendary.
        You can get a camshaft from Delta for a good deal less that should do what you want.
        Just keep in mind that a camshaft that provides a lopey idle will also give you less power down low. Your car will feel a good deal slower. If you’re not running at least an upgraded exhaust system, you won’t benefit from the high end gains either. I know you’re looking for the sound over performance, but just be aware that you’re likely to experience deminished performance if the camshaft is all you’re adding.
          Hmm, thnks man. I'll private message you if you don't mind, I've got a few questions.
