Transmission downshifts into second gear
    I have a '92 Accord LX. When it is sunny there isn't as much of an issue. When it rains however the transmission will downshift into what I think is 2nd gear. D4 light is on. I tried pulling codes from the blue terminal in the passenger side foot well and the d4 light will turn off when going to fully off to battery position. The issue does sometimes happen when it is sunny. but there is usually some rain activity during that week if it does happen.
    To read the codes, jump the connector, then turn the key to the "on" position. If there are codes stored, the D4 light will flash. Long flash = 10, short flash = 1. Count the flashes, then let us know the code. Pull the carpet up at the passenger foot well and see if you're getting any water draining into the area of the computers (mounted to a metal plate you'll see under the carpet).
