Auto tranny delaying to engage.
    Hey guys, well for the longest time my transmission has taken a while to engage into gear. I will start the car, shift to reverse but the car wont move and the "r" is not lit up on the dash. Then after a second or two it lights up and i can move. This also happens when putting it into drive aswell. I was wondering if any of you guys have had the same problem. Any input is welcome
    The start of something good
    Tcu maybe idk. Shift solenoid possibly. I also have a problem taking mine out of P when its cold. What I mean is the stick is hard to move out of P. Anyone with ideas on what that is should plz just give me a quick word without destroying the topic. Give the OP an answer first.
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
    ― Jeremy Clarkson
    Very first tear down and rebuild. vvv
    http://www.cb7tuner.com/vbb/showthread.php?t=193755"]http://www.cb7tuner.com/vbb/showthread.php?t=193755"]http://www.cb7tuner.com/vbb/showthread.php?t=193755
    Current Build, F23 block F22b dohc head:
    http://www.cb7tuner.com/vbb/showthread.php?t=203144
      shift cable too loose?
      visit vgruk
        Check your ATF level.
        Use a test light on the solenoids on the transmission.
        Try swapping TCUs.
        I doubt it is a cable problem, but a binding cable may be Mishakol129's issue.
