I just bought my 91 yesterday for $700. I think it needs an iacv, the idle throbs (only when not moving though), but I'm not sure. My 00' civic had a bad iacv but the idle didn't throb, it just was different every time I stopped. The throbbing idle went away after about 2 hours of driving though, and started again after I shut it off and turned it back on. The transmission grinds going into third, I'm not sure what's causing this though. It doesn't pop out, it shifts smoothly into every gear, but second and third take a little bit more effort (and a few times fourth too) and third grinds going into (but not coming out of) gear, no matter how fast I'm driving or how fast the engine is running. I also have a dead gauge cluster but I'm not too worried about that for now. Other than that, the car is fine (or at least I haven't noticed other issues).
91 w/ transmission problem and idle problem?
Idle issue could be numerous things but the IACV or FITV should be checked. I'd check the site for other answers as there are many causes.
The grind into 3rd is most likely a bad syncro. I would check the tranny fluid first and make sure you use Honda fluids. You can try double clutching but it is still a bad syncro and nothing you can do but try to change the defective part.
Best of luck.
Originally posted by Raf99 View PostIdle issue could be numerous things but the IACV or FITV should be checked. I'd check the site for other answers as there are many causes.
Best of luck.
Yay!! It worked! Thank you!!
Now for some confusion... It wasn't the slave cylinder. There's something (a valve?) in between the master and slave cylinder that I think is leaking (hard to tell, everything is wet) but I'm able to drive the car, my father got in and pumped the clutch, started it, and it drove fine (we drove it about 5 miles, stopping multiple times). He thinks there's air in the line, but has never worked on a Honda. I'm going to bleed the line and see if that helps. One quick question about the transmission, how do I check the fluid? It looks like there's supposed to be a dipstick, but there isn't one. If there should be one, where can I buy a replacement?
I cleaned the iacv and fitv earlier, cleaning the iacv helped, but didn't fix it. I ordered a new iacv and that should (hopefully) fix the issue.
No dipstick on standard transmissions, sir.
There's a fill hole and a drain hole. You have enough fluid when the full bolt starts to dribble on a flat surface. If you're doing a fluid change, it's a bit more than 2 quarts.
Eric The Car Guy does a DIY on bleeding a clutch. YouTube his channel.
Originally posted by F22Chris View PostNo dipstick on standard transmissions, sir.
Originally posted by mikemc422 View PostSo... I replaced the iacv ($220) and it helped (a little bit, not enough though), but definitely didn't fix the problem. The idle is still surging, and the car still jumps a little (probably from idle) at low speeds.
It may have backed itself out. If so, screw it down and put some grey gasket goop on it to keep it from loosening again.
Ok so I got it idling smooth now (the white plastic piece in the fitv had no tread, it kept popping out) and it drives good, except for in 1st/2nd gear it still occasionally jumps, and the idle seems low (I think it's close to stalling, I know that it shakes at idle because it's too low, but my tachometer doesn't work) how do I know when the idle is good now? Do I just adjust the idle screw until it stops shaking?
