EXT : CV Axles
    That fork is dangerous to the ball joint if your not careful!
    I used this method to remove the ball joint: Honda painless ball joint removal
    http://www.youtube.com/watch?v=ISY8bGof3bQ
    MRT: http://www.cd5tuner.com/vbb/showthread.php?t=5748
      I didn't see anyone state this yet.
      But an issue I had when removing my LBJ was that the nut was spinning with the balljoint. So when I tried to loosen it, it would just keep turning.
      If this happens to you. Just up the Lower Control Arm at the tip near the rotor and put a flat head screw driver inbetween the nut and the Control Arm.
      Apply some pressure to that by pushing the flat head(Or pry bar which I used) up wards and just loosen it that way.
      Nice diy though.
        Reignstarz
        This thread will be going to the DIY section, so that kind of information is great! Thanks for the tip!
        Project wagon! Much excite! 2018!
        That Sedan. Purchased '07-->Swap'd-->Tuck'd-->Wreck'd-->May '16
          Originally posted by gloryaccordy View Post
          Nice DIY. I've found disconnecting the tie rod and spinning the knuckle out of the way helps too.
          Instead of disconnecting the ball joint?
          Touching the tie rod can necessitate an alignment, though.
            oh my fing begees...I love seeing chicks work on cars...and diggin' the no fx t
            thanks for a well thought out diy with good pics!
            oh yeah you're cute
            ____
              You're just disconnecting it, not really tampering with it. To me that's much safer + cheaper than disconnecting and possibly destroying a lower ball joint.
              Originally posted by lordoja
                Installing CV axles; so easy a girl can do it!
                Well done!
                1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
                2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
                  Well done!
                  Chauvinist.
                  This was really for noobs, people (perhaps some women) who have never attempted to fix their own car.
                  Really... If you are to say "well done", you ought not insult me first.
                    That was very well done props
                    The CB7 Collector.
                    92 LX Coupe F22A1
                    2013 Toyota Corolla S
                    92 EX Sedan F22A1
                      Thank you!
                        i wish i had power tools lol
                          LadyG....Great Write-up I could have used this about 4yrs earlier
                          x2
                          -1993 Accord EX SOLD
                          -2012 GMC Canyon V8 4x4
                            i had to use the "pickle fork" ball joint sperator in doing mine, thats the only one autozone carry's for a ball joint remover. i tried that utube video but that didnt work.
                            good write up, you make it look much eaiser than when i did mine for the first time.
                              wow a chick changing an axle..that's sexy as hell...
                              well done
                              i know guys that can't even check their oil level..
                              Ride: 2002 Lexus IS300
                                mine snapped completly because the bolt off the stabilizer bar broke and the wheel cocked backk and got stuck and the boot completlely ripped in half and is now hanging(right side)...will it be harder to change it like that
                                Team Accord #17 F & H series or no series....Rota Slips are the new steelies -_-
