Hello I have a 1990 HONDA ACCORD newly sound as of 3-4 weeks ago it literally sounds like a bad bearing but it only happens between maybe 1,000-1,200 rpm's and I noticed it gets louder if I press on the air filter box is there anything around that area that would be a bad bearing and would get worse when pressing on the air filter box? I noticed it's been getting a little worse too started doing it at idle just today.
Bad Bearing Noise Under/near Air Filter
Hi,
The transmission motor mount is directly under the air filter box. Try lifting up on the box to see if the sound stops. If it does then its just something vibrating at that RPM level and would get louder if you pressed on it. Maybe a bracket hose clamp or even the plastic intake pipe that is routed along the fender.. Check all of that and see if you can isolate and stop and start the sound. The air box has mounting bolts on the bottom side under the filter. Take the filter out and see if any of these bolts are loose and vibrating...
Thanks,
Mac
Hmm is it hard to replace that motor mount? I've also noticed recently that the engine shifts alot when changing from park to reverse or drive along with a loud clicking noise that I've never heard on this car before so I'm assuming its the motor mounts? Where can I get a good set of motor mounts without paying out the ass? LOL And any information on installation would be greatly appreciated
Depends upon how long you are going to have your car, and whether you are more performance oriented or comfort.
If your going for cheap, it is not uncommon for people to fill their old mounts with polyurethane.
If your going for comfort, OE style rubber mounts should do the trick, which should last several years.
If going for performance, or plan on having the car a long time, it might be best to invest in some ESP (Explicit Speed Performance) mounts, as they will probably outlast your car, plus replacing Motor Mounts can be a major PITA, I'd rather do it once and have it last, then to have to do it again.
Also if one mount is bad, its very well possible the others have been damaged because of it, so inspect your mounts for cracks/fractures in the rubber to make the best determination on the severity.
Is it possible just to refill the motor mount? Because the main problem is bad vibration at idle. If so how do I go about doing so? I am looking to keep the car for years it's my newspaper carrier car LOL :P I am looking to spend maybe 100-300 on mounts less depending on if I can install them myself.
Originally posted by kevinhughes13 View PostIs it possible just to refill the motor mount? Because the main problem is bad vibration at idle. If so how do I go about doing so? I am looking to keep the car for years it's my newspaper carrier car LOL :P I am looking to spend maybe 100-300 on mounts less depending on if I can install them myself.
There are a bunch of different threads on various parts of motor mounts, whether repair, or installation, to find that thread I clicked on the search bar, in the top left search keywords I typed 'motor mounts', then towards the bottom right, I selected the DIY section, hit search, and found that as the 5th item.
+1 on the motor mounts, seeing as it is a vehicle you use for your papers, i would assume you would want it to be as reliable as possible. I would recommend the OEM replacement mounts as cloudasc stated above. "performance" oriented motor mounts usually tend to be stiffer and can sometimes cause a rougher feeling idle, due to the added vibration. Since it is a vehicle you would probably be in for at least a couple hours a day I do not think that you would want a rougher idle. The DIY fix will be cheap. But also not last as long as the proper OEM replacement, and i speak with no personal experience but i do believe filling them with polyurethane would also cause unwanted vibration.
