illinois_erik : 1992 Accord LX
    I came across this CB when looking for replacement interior for a 93 SE.
    After I found out all he did was throw a rod in the original engine, I decide to pay a bit more then scrap value as that what his plans were after parting it out. 400 bucks later I had a decent roller to invest time in since the 93 SE was a lost cause. Mint Blue untouched Interior, except for a few things spray painted on the dash.
    I have Facebook and usually drop photos to a dedicated album on there of my progress..check it out if you want:
    https://www.facebook.com/media/set/?...1&l=51a3b004b5
    1992 Accord LX Sedan - White
    Mods:
    Suspension:
    H&R sport cup kit.
    New poly bushes where applicable
    ESP Traction Bar w/front motor mount
    F&R ESP Strut tower bars
    F&R Adjustable UCA's
    SS Brake lines
    Speed Bleeder caliper bleeders.
    Engine:
    ESP Poly Mounts
    JDM 96 H22A
    -B/S delete
    -Gasket Matched I/E
    -Cylinder Head P&P
    -Cleaned Up Intake Plenum & Runners and Exhaust Header Ports
    -EGR Delete
    -FITV Delete
    -No Airboost lol
    HighEnd Autosports tri-Y exhuast header
    -2.5" Mandrel Bent stainless exhaust
    -18" Magnaflow Resonator
    -Vibrant Streetpower Dual Outlet Muffler
    -deciding on cat or pipe.(depends on fitment)
    Transmission:
    ESP Poly Mounts
    JDM LSD H22A Automatic
    Extreme Service Transmission Cooler
    Cooling:
    Civic Half Size Triple Core Aluminum Radiator
    Aluminum Fan Shroud
    12" 1000CFM Slim Fan
    Exterior:
    All LED Light Conversion
    Nokya Lows and Highs
    Solid State Flasher
    All Clear Taillights
    Clear Front Turn Signals
    JDM OEM Window Vents
    Rear Visor
    *Aftermarket OEM Style Wing Delete
    *Antenna Shave
    To Come: *Already acquired
    Rear Disc Swap/ Cross Beam/ Sway Bar
    Poly and Hard rubber upgrade to rear suspension
    25T Front Brembo Wagon Discs/ NSX calipers/ Wagon Brackets
    Fog Lights refurbished with LED's
    Reusing old drilled/slotted rotors for now
    Did this a couple weeks ago..just getting everything preassembled.
      more pics, the writing sounds nice but i wanna see it.
      CB7TUNER.com
        Its just sitting now..Im very unmotivated and unemployed
          Refurbished the front sway bar
          I forgot whom it was but their sway bar rotted away enough on the ends to break. Im not having that. Theyre pretty flimsy as it is. So I removed all corrosion, cold galvanised it and top coated. I will use silicon grease upon reassembly along with poly endlinks and bushings..Just kind of whittling away at things
          Before:
          After:
            Good to see an MRT from you. I have been wanting to see your CB project(s) for a long time now. I love white CBs!
            MRT
            Selling on Ebay!
            15.10 @ 90.42mph
              Thanks for checking it out and being interested..Im partial to the white one myself..itll look so clean!
              and on another note..Im glad I double check things, especially when totally dismantling stuff (i probably should have taken a bunch of pictures..lazy!) I installed the front shock hat bushings upside down..they went in easier that way, but I remedied that tonite. I think I have my wish bones/shocks mixed up though..Im glad I have a CD5 to cross reference against for those little things and the online honda parts sites with their blown up diagrams..life saver for sure..
                Installed block and trans today
                Got the block and trans installed today by myself with a floor jack some ratchet straps and a few pieces of wood.
                Now i think things will pick up speed.
                I was going to use the harness that came with the H to make the swap subharness but Ive decided to just buy one from rywire, then after that its just buying coolant hoses, fluids and getting it all back together.
                Tonite Ill get the trans hooked up to the shifter cable, bolt the flex plate to the torque converter and might put the front suspension all back together.
                The other day I put in my refurbished sway bar, poly bushings, lower control arms and the poly endlinks
                  Dang, dude! Things are getting going real fast now!
                  MRT
                  Selling on Ebay!
                  15.10 @ 90.42mph
                    Looks like a simple and clean build. What's with the tires in the background?
                    YouTube Clicky!!
                      nice keep up the good work
                      " Insert funny quote here "
                        Thanks..yes the hard parts pretty much done
                        Thanks, just something Ill be keeping and enjoying for a long time I hope. Those are just some mounted 14's for winter and some loose 15's Ive stockpiled
                        Danke, now that the summer heat has broke I hope to get it done before it gets too cold.
                        When I remember Ill take some interior pics..so mint.
                          Lookin good!
                            Originally posted by JunyAccord View Post
                            Lookin good!
                            Thanks..Hey you live in my old stomping grounds I lived in Skokie most of my childhood from 88-97, Went to Niles West while it was still the Indians
                              I only lived here for about 2 years. I used to live by norridge/harwood heights back when I was in the CB game.
                              But yeah once you're up and running we should go on a cruise downtown
