Old 10-23-2009, 11:07 PM   #1
low-keyseg92
low-keyseg92 is cool... so far.
tranny question
I have an automatic ex. The light that shows what gear the car is in flashes but only the D ( for drive) flashes. If I put it in reverse or any other gear the D still flashes. I looked in the Haynes but found nothing. Any ideas? THanks
low-keyseg92 is offline   Reply With Quote
Old 10-23-2009, 11:29 PM   #2
crusto2k3
crusto2k3 is cool... so far.
dude, have you searched at all
http://www.cb7tuner.com/vbb/showthre...ight=tcu+codes
My Honda
crusto2k3 is offline   Reply With Quote
Old 10-23-2009, 11:31 PM   #3
low-keyseg92
I did some searching...either way, im thinking it might be the VSS. I drained the tranny fluid before I pulled the motor. I also pulled the radiator. Is it necessary to bleed the system? I will pull the codes in teh morning and post my findings. I did not know you could pull tranny codes like with an ECU. Im used to manual Civics. My car shifts fine a accelerates good. It seems to shift down kinda hard when slowing for a light tho. Otherwise running good.
Old 10-23-2009, 11:32 PM   #4
low-keyseg92
Sorry in a hurry because my internet shuts off here at work at midnight. lol. I wanted to get my post in before it shut off. Im old enough smartass....thanks for the link.
Old 10-23-2009, 11:33 PM   #5
crusto2k3
you're welcome
My Honda
Old 10-23-2009, 11:37 PM   #6
low-keyseg92
I have had a rough day thanks for not flaming me to bad. I usually search first....im not a noob to the internet, I just got in a rush. Ill post what I find tomorrow.
Old 10-23-2009, 11:40 PM   #7
crusto2k3
word...good luck
My Honda
Old 10-27-2009, 08:42 AM   #8
low-keyseg92
code 9...nc speed sensor. It dont look to hard to replace. Now to call the parts store to see if they have it. Thanks for the help.
Old 10-27-2009, 09:07 AM   #9
deevergote
Don't call me dude.
Check the wires going to the sensor first. It may be as simple as a bad connection.
Old 10-27-2009, 05:10 PM   #10
low-keyseg92
Ha Ha it was a bad connection...as in it was not even plugged in. Thats what happens when you work on a car for a week straight after it sits for 10 months and you are tired of working on it...lol. Thanks for the help.
auto tranny , drive , light flashing
