Old 10-11-2014, 03:19 PM   #1
johnny_h
Newcomer
johnny_h is cool... so far.
Cooling Fans
I noticed that my car's temperature was starting to go up while I had it idling in park. So I pooped the hood open and I noticed that only one fan was on. Are both fans supposed to turn on at the same time?
johnny_h is offline   Reply With Quote
Old 10-11-2014, 04:42 PM   #2
cb9love
CB7tuner Member
cb9love is cool... so far.
no both fans do not kick on at the same time . the one on the drivers side is for the A/c, the one on the passenger side is for the cooling system. Most times the A/C fan does'nt kick on unless the A/C is on.
__________________
CB7TUNER.com
Educating each other one car at a time.
cb9love is offline   Reply With Quote
Old 10-11-2014, 06:09 PM   #3
sonikaccord
Contributing Member
sonikaccord seems to have made some friends!
Check your coolant level, it may be low. btw
__________________
YouTube Clicky!!
sonikaccord is offline   Reply With Quote
Old 10-11-2014, 10:30 PM   #4
johnny_h
Newcomer
Quote:
The drivers side fan is the one that kicked on when the car temp climbed, the passengers side can is the one that didn't kick on.
But I will double check the coolant levels
Old 10-11-2014, 11:14 PM   #5
illinois_erik
CB7tuner Member
illinois_erik is very helpful illinois_erik is very helpful illinois_erik is very helpful
passenger side is system cooling, driver side is for a/c. so id check the fan and relay.
__________________
illinois_erik is offline   Reply With Quote
Old 10-11-2014, 11:37 PM   #6
johnny_h
Newcomer
Quote:
http://youtu.be/poep_18dEw4
Check out this video, dudes says that the passengers side fan is for the a/c
Old 10-12-2014, 02:11 AM   #7
illinois_erik
CB7tuner Member
cool, i deleted my a/c...
__________________
Old 10-12-2014, 06:41 AM   #8
Bossman
Newcomer
Bossman is cool... so far.
He's wrong. The condenser fan is on the driver's side.
Bossman is offline   Reply With Quote
Old 10-12-2014, 09:34 AM   #9
johnny_h
Newcomer
Quote:
Yea, you guys are right, this dude is wrong. I dug for more info and every place I looked said that the drivers side fan was the a/c condenser fan.
So that means that in my car, the radiator fan isn't turning on and the a/c fan is turning on to compensate for that?
Old 10-13-2014, 05:13 PM   #10
Taurians' Ryde
CB7tuner Member
Taurians' Ryde is cool... so far.
Send a message via MSN to Taurians' Ryde
Start by going to the thermostat housing by following the lower rad hose. Disconnect the green 2 wire electrical connector and jump it with a paperclip. If the passenger fan turns on then it's your thermo switch that the green boot connects to. That was my issue...the thermo switch wasn't closing to complete the circuit to turn the fan on.
Taurians' Ryde is offline   Reply With Quote
