Old 02-03-2012, 10:54 AM   #1
BurninCB7
BurninCB7 is cool... so far.
Post New Ball Joints and other Suspension advice needed
I ordered new ball joints, upper control arms, tie rods (inner and outer), and sway bar link kit. The plan is to put the BJ's on the EX, and tie rods/sway bar linkage on the LX.
I already know how to install all these parts, but I am wondering if there is anything I can mess up while installing everything.
How do ball joints effect camber? I am mostly worried about the alignment. I plan to get an alignment done in a few weeks, but I don't have the funds to right now.
Any tips/tricks/horror stories/stupid fails/success stories/things-you-only-learn-from-experience and/or advice would be greatly appreciated.
Once again, I already know how to install, I am simply asking about possible effects of new components.
'91 EX 280,000 || '90 LX 330,000
_____(me)__________(wife)___
BurninCB7 is offline   Reply With Quote
Old 02-03-2012, 11:23 AM   #2
19dabeast85
19dabeast85 is cool... so far.
Installation will very likely cause a miss alignment as you know, you are replacing worn components that have slop with new, solid components. You CAN drive for a couple weeks if you get your tie rod back close to where the old one was....remember it's better for the front tires to point IN /_\ than to point out \_/.
I say wait until you have the funds for an alignment before doing the job....really no point in replacing it now unless something is critically damaged and a safety concern.
My Member's Ride Thread
19dabeast85 is offline   Reply With Quote
Old 02-03-2012, 11:41 AM   #3
C91BLX7
C91BLX7 is very helpful C91BLX7 is very helpful C91BLX7 is very helpful
Messing with tierods = need alignment.
wat?
C91BLX7 is offline   Reply With Quote
Old 02-03-2012, 01:42 PM   #4
BurninCB7
The tie-rods on my LX (325k, mind you) have quite a bit of play in them. You can feel it down on the ground (whilst on jacks), but the steering is good and tight while driving. I am a bit concerned with that, as this is my wife's car and she does not know the signs of failure. I had a 4wheeler almost kill me when a tie-rod snapped while I was flying through the forest. So it does indeed worry me
Do ball joints effect steering very much? I mean, they obviously have some influence on steering because they support the knuckle, but will I notice a difference in the steering after replacing the BJ's? The upper control arm bj has a little bit of play and the boots are broken all around (on the EX). It also needs rear control arms. Should I be concerned with the rear(s)? The rear passenger side gives me a 'clunk' when I turn. Is that a safety issue? Should I focus on getting that replaced?
I'm so stoked to get my babies running smooth and quiet. I got a full gasket kit for the EX today, gonna pull the motor in a few weeks and give it a quick refresh. Gotta get a timing belt/water pump kit and it's in the works.
Thanks for the replies! Every little bit of knowledge accrued before I start helps in the end. ...Accrued, not in the monetary sense, but in the sense of receiving said knowledge...
Forever working on my CB's = Labor of Love
Old 02-03-2012, 01:47 PM   #5
Cb_JoeyG
Cb_JoeyG is cool... so far.
Just curious, but where did you get those susp components from? It wasnt one of those 100$ combo kit deal on ebay was it?
8 Accords so far:
Cb_JoeyG is offline   Reply With Quote
Old 02-03-2012, 02:02 PM   #6
dhill_cb7
dhill_cb7 seems to have made some friends! dhill_cb7 seems to have made some friends!
I did my uppers (whole arm, forget price) just bought lbjs from honda oem(22 a piece!)
I would always buy oem honda ball joints. Not worth risking your life on cheap after market.
Tie rods inner and outter honda wanted 80 a piece.....so they will have to wait....
Def get an alignment asap! I did not afterward and it ate through my tires.
But if your able to do the work and do it right i would say go for it, honestly i would wait until every thing is replaced before you get an alignment. They tell you they won't align your vehicle if there is still damaged bushings or ball joints.
dhill_cb7 is offline   Reply With Quote
Old 02-04-2012, 05:45 PM   #7
BurninCB7
I got everything but the lbj's on ebay. They are from a reputable dealer that another tuner had recommended. All together it was about $175
Old 02-06-2012, 10:26 AM   #8
noahrexion
noahrexion may have said something they shouldn't have...
Prepare to do those over when they fail in 6 months.
noahrexion is offline   Reply With Quote
ball joint upper control , ball joints suspension , suspension , tie-rod
