Old 04-09-2012, 04:59 AM   #1
Lucky#CB7
Lucky#CB7 is cool... so far.
Car is making odd noises...dont know where to start
recently my car has been making 2 odd noises
1. when i turn my steering wheel, it makes a loud whining noise! don't know if its the p/s pump or belt (yes, there is a sufficient amount of fluid in reservoir)
2. again, when i turn my wheel i hear a clunking/popping noise. not 100% where its coming from but it seems to be from my left side.
Any input would be much appreciated! thanks
Lucky#CB7 is offline   Reply With Quote
Old 04-09-2012, 07:45 AM   #2
stunin92_accord
stunin92_accord is cool... so far.
1) your power steering motor needs to be cleaned out,try flushing out the old fluids and refill with fresh p/s fluid.
2)if you are making a full right turn then you would hear the clunking coming from your left cv joint.if you make a full left turn then you would hear the clunking coming from your right cv joint..
stunin92_accord is offline   Reply With Quote
Old 04-09-2012, 03:40 PM   #3
Nokomp
Nokomp is cool... so far.
Send a message via Yahoo to Nokomp
pwr steering- i cant advise you on this dont use them sorry.
CV AXLES- DIY tools you will need
36mm 1/2dr socket & the largest breaker bar you can find/Impact
Jack & stands
Ball joint tool- i prefer the fork like ones for the lower ball joint btw this is the only one you need to remove to take off your cv.
14mm socket/wrench for pinch bolt behind ur strut
17mm socket/wrench for the long bolt @ the bottom of your strut "FORK" strut (shock & spring) removal not neccesary for cv axle removal, the only parts that need to be taken off are you wheel, lower ball joint, and the strut FORK, gently use a large flat head screwdriver to pry cv out of intermediate shaft(left side)trans(right side)
My personal tips: add a smug of grease everywhere there is metal to metal contact(hub spline, ball joint sleeve, strut fork bolt) makes ur life easier next time.
Nokomp is offline   Reply With Quote
Old 04-09-2012, 03:50 PM   #4
Oreellyfool
Oreellyfool is cool... so far.
When my PS reservoir is below the fill line, my pump starts whining, and after I fill it up, it stops. Something to try before a full clean.
The clicking is most likely from your CV joint going out. Replace that axle.
"There is nothing wrong with you that an expensive operation cannot prolong."
Oreellyfool is offline   Reply With Quote
Old 04-09-2012, 04:06 PM   #5
LastToBrake
LastToBrake seems to have made some friends! LastToBrake seems to have made some friends!
Agreed on #2 being the axle. Mine does the same thing, I've just been too busy with other projects to finish it.
LastToBrake is offline   Reply With Quote
Old 04-10-2012, 06:19 AM   #6
BurtonRiderT6
BurtonRiderT6 is very helpful BurtonRiderT6 is very helpful BurtonRiderT6 is very helpful
If you have a bad CV axle I suggest putting other projects off and fixing the routine maintenance first. You don't want to take a chance and have the joint separate.
BurtonRiderT6 is offline   Reply With Quote
Old 04-10-2012, 08:04 AM   #7
9_2_C_B_7
9_2_C_B_7 is cool... so far.
Def a CV axle or joint. I believe my CVjoint is starting to go out. Hope eveything gets fixed!
9_2_C_B_7 is offline   Reply With Quote
noises , power steering , suspension
