Hi all. i just got done taking off my oil pan (took me a while, my first time) because of a leak from a previously failed gasket job. I used a steel brush attached to a dremel and cleaned the gasket surface REALLY good as there was a LOT of RTV on it. I am using the Fel-Pro permadry silicone gasket (a hefty 20$). I will also be using, because someone recommended it, permatex silicone spray.
I wanna know what I should do exactly since I have heard about a hundred different ways of doing it (well not a hundred, that's an exaggeration).
I am thinking of just gluing the gasket to the pan with the permatex and then using some rtv on the corners and the humps of the rear main end as the manual says to. The manual I have (Honda manual) says to only use RTV there but not anywhere else, and it also says to torque to 10 ft lbs (which I will, unlike last time *DOH!*)
So what would you do? I would like to get some tips / tricks for this, everybody has their own methods and I would like to hear them.
Thank you very much..
