Old 12-28-2017, 03:42 PM   #61
G. Wiffington
I am slacking lol. So I never actually got to start my car after redoing the notch
in the front crossmember & doing the header wrap install. I have fixed that
noise I was complaining about. It was indeed the downpipe hitting the
crossmember. When I pulled the piping off you could see a mark on the DP
where it was hitting. I am glad it was a simple fix.
If only I had heat!!
Old 12-28-2017, 04:43 PM   #62
jchsmiley
Accord of the Month: March 2013
jchsmiley is cool... so far.
Did you ever go get it tuned?
jchsmiley is offline   Reply With Quote
Old 12-29-2017, 01:59 PM   #63
G. Wiffington
On the Dyno, nope. But, I have been tuning it with my buddy he is pretty good
with Hondata & tuning. I have also just been reading a lot on tuning as well as
learning on the Hondata forum. The Hondata Help Guide also has all the info to tune too.
I have been going off of the "Estimated Fuel Change" on the datalogs & adjusting accordingly
since I have my AEM Wideband connected to pin D10 going into the ECU.
It really doesn't seem too complicated as long as I have the WB.
Hopefully sometime in the spring I can get it professionally tuned on a dyno.
But, I am also not beating on the engine so just in case there is an issue I
think I should be okay.
Not sure of the HP or anything though which I would love to know!
Old 02-20-2018, 03:57 PM   #64
G. Wiffington
Over the weekend I have been working on the Rear Toe Arms & I think this has been the biggest pain so far on my CB.
Ever since I bought my CB it has had some alignment issues. Last year when I went to Firestone to get an alignment & the technician sais that my driver side toe was frozen & the passenger side was "maxed out".
I don't have my document in front of me but I think the rear toe....
Driver's Side was : 1.21
Passenger Side was : 0.80.
Very very toe'd in lol. The rear tires definitely wore down a lot. Which sucks because the front tires are perfect. It used to be very sketchy when driving because going around a turn with bumps made the rear of the car start moving back & forth.
Anyway, since my Driver's Side was frozen I had to cut out the bolt which was such a pain in the butt!! That bolt is pretty thick. This had to be the most difficult part of my suspension overall.
I finally got the arm out & the new one in on the Driver's Side with new Honda hardware. I did the string method to check the toe & it looks pretty close to 0.0 for toe.
I am now waiting for some spare time from work to finish up the passenger side. Hopefully I can get that done soon because the warm weather is coming!
Old 03-09-2018, 02:39 PM   #65
G. Wiffington
Installed a set of Megan Racing Adjustable Rear Lower Control Arms
A Little progress on my rear alignment issues. So after realizing I was having a Toe issue with my rear tires I went under to remove the toe arms but the bolts on both side were frozen to the bushing so of course I had to cut them out. On the first side (driver's) I used a metal blade with longer teeth so it made my cutting pretty difficult. I went to get a better blade with more "fine" teeth which made my cutting a lot easier.
Anyway..I installed new MOOG toe arms on both sides along with new Honda eccentric bolts, nuts, & the eccentric washers.
I set the toe as best as I could with the string method but I learned that there was an issue with the passenger side still because during the adjustment I could not get it to toe out anymore. Seemed like it was maxed out or the rear of the tire has been pushed out or the front of the tire was pushed in. I think sometime before the rear passenger side must have been either hit in an accident, or slid into a curb which was causing the front of the tire to turn inwards. Maybe the Trailing Arm is bent? Because when I was putting the ebay lower control arms (these were installed over a year ago) back on I was struggling to line up the long bolt that connect the control arm & the toe arm together.
So, I purchased the Megan Adjustable control arms that way I could make it the correct length. This might just be masking whatever the real issue is regarding this rear tire but it did work in my favor.
I adjusted both lower arms to the appropriate length & I now finally have a GOOD rear alignment for the first time since owning my CB.
All I need to do is hit Firestone to get an alignment. Or hopefully my buddy who works at Honda can hook me up lol.
I also bought Megan Racing Adjustable Toe Arms but I might just save that for when it gets warmer outside.
Old 06-22-2018, 04:02 PM   #66
G. Wiffington
I haven't uploaded anything in a while but, here are some pictures I have taken over the past two months or so.
This is the new driveway spot for my CB. It makes me nervous because my neighborhood is not the best & my driveway is front of my house.
I do not like how many people can see it sitting in my driveway. My old house used to have to driveway in the back alley so my car was hidden.
I should probably find an anti-theft DIY so I feel a little safer. I just do not want it to get stolen.
Old 06-22-2018, 04:06 PM   #67
G. Wiffington
Installed an Oil Catch Can
Old 06-22-2018, 04:38 PM   #68
G. Wiffington
I also have a new set of tires, Hankook Ventus V2 Concept2 205/50R16 ready to put on.
I also need to Re-Center my steering rack & redo the alignment for the entire car.
Old 07-09-2018, 03:07 PM   #69
excalibur02
Wanna be JDM whore
Do you have an alarm installed? Maybe add a kill switch?
Instagram username MAURO02
Old 07-09-2018, 08:43 PM   #70
Grumpys93
Locking hood pins, removable steering wheel, and a kill switch will all help deter but bring attention as well.
~Nick~
Old 07-20-2018, 04:44 PM   #71
G. Wiffington
Nope no alarm. A kill switch would be a good idea.
Old 07-20-2018, 04:45 PM   #72
G. Wiffington
Yeah true, my setup looks completely stock. I think I may go with a kill switch.
Old 09-12-2018, 09:33 AM   #73
G. Wiffington
So I was in the process of getting my CB ready to take to Honda Day this
weekend but, I think the Hurricane has other plans. Bummer..oh well.
I have been doing some work on it every now & then. The weather has been
a little crazy lately, just like work so I have only had limited time to mess
with it.
When I did my H22 swap I did the whole ABS delete & cleaned up my engine bay a little bit but I really wish I would have repainted it. So two weeks ago I was bored & did a little painting. I could not find a close enough color to my paint but I ended up finding a wheel paint that was pretty close. I think it looks pretty good considering I suck at painting.
The left picture was last fall & the picture on the right was the new paint.
Old 09-12-2018, 11:00 AM   #74
fleetw00d
Looks a lot better. For matching color paint: www.automotivetouchup.com
90 LX 4dr 5 spd 376,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Old 09-14-2018, 04:49 PM   #75
G. Wiffington
Thank you. I will have to use that site in the future.
Old 09-18-2018, 12:12 PM   #76
G. Wiffington
Honday Day Fall 2018
The weather decided to act somewhat decent this weekend so I ended up
taking the CB to Honda Day. My car has literally been sitting for 3 weeks until
Saturday when I finally started it. I only went on Sunday. This was the farthest
I have driven my car ever. The trip was about two hours away from where I live.
It was funny because it was actually like raining on the way there. I was about
to turn around & go home but I made it half was so I kept going.
I am glad I kept going because Honda Day was so much fun.
Old 09-18-2018, 12:18 PM   #77
G. Wiffington
I even got to go home with a cool little thing..
Old 09-18-2018, 02:10 PM   #78
NH-503P-3
NH-503P-3 is cool... so far.
Hell yeah! Nice. CB representing for Honda days. Much props to you!
~Mark~
Old 09-18-2018, 04:26 PM   #79
Grumpys93
Thatís awesome! Congrats on getting first place. Makes me want to attend car meets again.
~Nick~
Old 09-18-2018, 07:16 PM   #80
Raf99
So about your rear toe issue. I know from experience that someone who continuously jacks up on the rear subframe in the middle can affect the camber in the rear. I had an alignment guy tell me this and it was a good point. By deforming the metal (usually with a small jack) in the middle of the rear subframe will affect tow etc. Especially since it's measured in mm. (0.08, etc.). Your issues may be caused by a bad rear subframe.
Congrats on the award! You were the only one there older than 97 weren't ya :P
