1991 Accord EX
    1991 Accord EX
    I have a problem with my Accord, and I can't seem to solve it. It starts to vibrate after about an half an hour of driving it. At low speeds (20-40mph) it almost feels like a flat tire. It dosnt stop vibrating untill you stop giving gas, either holding one speed or slowing down. What could this be???
    JD
    lol I got the same problem...just go faster than 40 lol thats wat do,the previous owner said the shock on the driver side was bad...but i rides cool above 35
    1991 Sedan
    click image for MRT
    -Nava
      theres about 10 things that could be wrong.......i'd encourage you to search the forums first........and to post in the Beginner Technical/Performance instead of Off Topic.....you'll get way more replies that way.....
      make sure your wheel is on tight.....sounds so stupid its not worth checking, but a slightly loose wheel will cause mad vibration as it gradually works itself looser.
      make sure your bearings and balljoints and tie rods are all good....if they're bad, odds are you'll notice it throughout the powerband, but it could be an early sign.........
      just search the forums and re post this question in beginner tech/performance
      1992 Accord LX Wagon 248K/155 Miles
