Hi my ride is a accord 92 2.2 usdm. The brake fluid of master cilinder Down and go to the reservoir abs . The liquid flows throught the reserve abs.. Hu repair this problem?? I from argentina sorry for my inglish
problem brake / abs fluid
I had the same problem. There are some seals inside the modulator that stop sealing completely with age, hence some fluid gets transferred from the primary brake system to the ABS system.
I tried half-heartedly to take apart the modulator to see if the seals were servicable but gave up. I ended up getting another modulator from a salvage yard for about $80. It still transfers fluid, but slow enough that its not much of an issue. I would probably need to drain it every 3 months or so so it doesn't overflow.
There was one guy in the Acura forum with the same type of ABS system with the same problem. He installed a small rubber drain hose from the ABS reservoir to the master cylinder so that it will just drain back automatically. At first I thought this was a ridiculous and cheesy option but it seems like these modulators, after 20-25 years of service, all leak some amount. You would just need to remove the reservoirs and drill a small hole with a barb fitting. If you were careful you probably wouldn't even need to bleed the system afterward.1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
Stock F22A6
VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
H23A1 powered
NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
