so i finally got my coupe running if you ever run into a no spark or fuel problem after you have checked your main relay, your distributor, and fuel pump check and see if your ecu is grounded out that was the problem with mine but i guess that's what you get when you swap engines...
hmmmmmm another cb7 to the cb7 nation
