Go Back   CB7Tuner Forums > Parts & Performance > Suspension
Old 12-27-2016, 06:45 PM   #21
fleetw00d
Contributing Member
fleetw00d seems to have made some friends! fleetw00d seems to have made some friends!
Quote:
Originally Posted by G. Wiffington View Post
I know this seems like a dumb question but, does anybody know exactly what
the part number for the rear lower strut bolt?
I found : 90021-SM4-003 part #15 http://www.hondaautomotiveparts.com/...ER&vinsrch=yes
I also found : 52366-SM4-003 part #26 http://www.hondaautomotiveparts.com/...RM&vinsrch=yes
The first one (#15) is the bolt for the lower end of the shock to the knuckle.
The second one (#26) goes through the outer end of both control arms and the knuckle; it is at least twice as long as the first.
__________________
A million+ miles!
90 LX 4dr 5 spd 353,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 234,000 MRT:http://www.cb7tuner.com/vbb/showthread.php?t=208490
93 EX 4 dr auto 175,000 (sold 2/24/2017)
92 EX coupe auto 163,000 - MRT:http://www.cb7tuner.com/vbb/showthread.php?t=205114
93 SE coupe 202,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=208524
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583
Old 12-29-2016, 08:39 AM   #22
G. Wiffington
CB7tuner Member
G. Wiffington is cool... so far.
Thanks, I was at work the other day looking at the diagram. I crawled under my car after work & looked. I appreciate the help.
G. Wiffington is offline   Reply With Quote
Old 04-15-2017, 09:50 AM   #23
G. Wiffington
CB7tuner Member
Quote:
Originally Posted by illinois_erik View Post
if you have at the minimum a torch hacksaw blade, hammer, old screwdriver or cold chisel and maybe a pointy punch you can remove the oem ones properly
getting the new RUBBER ones in just requires some sand paper, grease a stack of fender washers, bolt and nut and some wrenches.
monroe makes them for 12 bucks a pop.
**I just installed my whole suspension (shocks, springs) & I replaced these lower strut mount bushings. This method is the one I used & was probably the easiest procedure on my CB so far regarding suspension.
Old 04-21-2017, 07:05 AM   #24
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
I wish I had seen that method when I did mine! That would have made things so much easier!
__________________
BUY MY STUFF!!!
NEW PRICES ADDED 09/24/2016
AEM TruTime cam gears (H22A), DSM 450cc injectors, Eaton M45 superchrager
deevergote is offline   Reply With Quote
Old 04-26-2017, 12:54 PM   #25
G. Wiffington
CB7tuner Member
Quote:
I forgot to post an update to this. I did use this method with the washers & long bolt. It was by far the EASIEST way I have ever pressed in a bushing. It is amazing how little techniques like that make a job so much easier.
I also used a 1 1/4" hole saw drill bit to remove the inner metal piece as well as the bushing. That literally took 30 seconds max on each side.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
