Old 06-25-2011, 11:58 PM   #1
TreyDaBurna
TreyDaBurna is cool... so far.
Send a message via AIM to TreyDaBurna
On The Road To Turbo
Ok cb7 family I'm Officially on the road to turbo what I'm workin wit is a f20a sohc motor I wanna know what should I upgrade on the internalls before installing the turbo..I plan to go with a dsm set up and run probably no more than 10 psi maybe more if I can.....idk if my block should be sleeved or if I should upgrade my cam ,crank,rods,pistons, I'm clueless just becuz its a f20a sohc.....I have done my research and my engine is not to popular.....good ass engine tho....let me have y'all opinions
TreyDaBurna is offline   Reply With Quote
Old 06-26-2011, 01:32 AM   #2
k20si
k20si is cool... so far.
Silly putty!!! That will help the cylinder walls. First pull your motor. Then open it up and spread a thin coat of silly putty on the cylinder walls, now dont get carried away this is a important part of building your Race car motor. Did you know if you spell race car back words its spells race car... Anyways after your thin coat of silly putty on the cylinder walls. You need to make it so the rods dont bend, break or fly thru your silly putty covered cylinder walls. So remove the rods and put them some place safe like under the fridge or a shoe box. Now for the cam I suggest spending a lot of money on this part of the race car motor. Head for the kitchen and get your mommas mop handle. While your there get a nice steak knife and you can make your custom cam profile. The money spent on this part of the race car motor will be in the ER when you cut your hand open. Pistons, well any old cut in half 40oz OLd E can will work for this... Id say if you build it like this your looking at 400+ hp. hope this helps good luck on your build... racecar<><<>racecar
K20z3
k20si is offline   Reply With Quote
Old 06-26-2011, 01:51 AM   #3
k20si
Start here
http://www.cb7tuner.com/vbb/search.php?searchid=6820790
K20z3
Old 06-26-2011, 10:50 PM   #4
GeoffM
Administrator
GeoffM seems to have made some friends! GeoffM seems to have made some friends!
What the hell?
OP, for the F22ax, the rings will go first. Not sure with the F20
MRT
Originally Posted by Tippey764 View Post
sneaky motherfucker
GeoffM is offline   Reply With Quote
Old 06-26-2011, 11:09 PM   #5
quaidum
Location: merritt island FL where the shuttle WAS launched
quaidum is cool... so far.
Originally Posted by GeoffM View Post
What the hell?
more than likely the ringlands not the rings themselves
''COUPE''
''WAGON''
quaidum is offline   Reply With Quote
Old 06-26-2011, 11:13 PM   #6
GeoffM
Administrator
My bad, I didn't even know there was a difference. I thought they could be used interchangeably.
So the cure for that is what, new pistons?
MRT
sneaky motherfucker
Old 06-26-2011, 11:21 PM   #7
TreyDaBurna
Well anybody got any ideas on internal upgrades.....
Old 06-26-2011, 11:26 PM   #8
GeoffM
Administrator
http://bisimoto.com/store/index.php?...roducts_id=311
and
http://bisimoto.com/store/index.php?...roducts_id=278
MRT
sneaky motherfucker
Old 06-27-2011, 01:41 AM   #9
TreyDaBurna
Appreciated bro....takes car of internals ...what about sleeving yah or nah
f20a , sohc , turbo , wannago
