Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Forced Induction
Old 03-25-2012, 02:51 AM   #1
beyonddalimit
beyonddalimit is cool... so far.
Need help asap!!! Need to knw what ecu I can run with my setup.
I need to know what chip ecu I can go with my setup. I was thinking of goin with a p06. Let know your guys opinion.
Specs:h23a3 non v, t3 t4 turbo with 7psi spring. Not currently running due to more parts i have to pick up... (255 walbro pump, 450cc inj.,)
beyonddalimit is offline   Reply With Quote
Old 03-25-2012, 02:54 AM   #2
dj_ender
Mod\Dubstep Pusher
You need to get the ECU your tuner is comfortable using, could be a P06 or a P28, either will work as well.
Old 03-25-2012, 05:32 AM   #3
cloudasc
cloudasc is someone to admire cloudasc is someone to admire cloudasc is someone to admire
If he doesn't doesn't have vtec, he can just use a p06, and add the circuitry to control the butterfly in the intake (IAB's), and maybe even add the EGR/Boost PWM functionality.
p06's are easier and cheaper to find then a p28 typically, and just by adding a few components can give the same or more functionality then the you could use.
My p06 has the circuitry for vtec, egr/pwm boost, and iab functionality added to it, so its the equivalent to a p72 w/o knock. Cost me less then $100 for parts and the ecu itself.
Then after its "chipped", its up to you what software you would like to have used to tune, and then find your tuner that way.
Finding an tuner that supports ectune or neptune (You need a moates demon / ostrich & hulog) would probably be the cheapest route, or you could always look at the hondata setup.
cloudasc is offline   Reply With Quote
turbo , turbo build
