Old 08-10-2017, 01:45 AM   #1
Carbonaccord
Carbonaccord is cool... so far.
FP race manifold (DSM) on f22a/h23 turbo build
Overview: To my knowlege nobody else has tried running a high performance aftermarket Forced Performance manifold on an F22 with a dsm turbo set up. I did some research and read reviews on this manifold over on the dsm tuner forums and found that this is a direct plug and play swap for the oem 1g and 2g manifolds. Meaning it doesn't relocate the turbo any when compared to the oe manifold. So any f22/h23 dsm turbo guys. This manifold is where its at.
I purchased this manifold for 220 shipped and Paypal fees via FB used and with only 4k miles on it!
Pros: (just about everything!)
-smooth larger runners
Doesn't need that exhaust pulse separator that the oe manifolds need.
-smooth equal collector makes for a nice rumbly exhaust note (like a 4-1 header)
-flows tons better
-same cast iron and nickel content that turbine housings are made of so it's well built and not prone to cracking over cheap ebay tubular manifolds or oe stuff when you crank up the boost and heat!
-a pro to this manifold for our f series engines is that the exhaust ports are slightly larger than than the ports on the head (this is fine and according to Jafromobile, desireable, i assume it has something to do with flow)
Fitment: as far as fitting the manifold onto the head, required modification is as follows.
Take an old exhaust manifold gasket and center it as best as possible to the ports on the manifold. Once you've secured the gasket with some masking tape or whatever bust out a new brightly colored dry erase marker and mark out the areas that need to be drilled/ground out. You may also do this with a thin scribe
Next would be to grind out the areas you just marked. However i found that a dremel and orange grinding bits dont cut quite as fast as a drill milling machine would with a small end mill. The next easiest way without having such a fancy shop and mill at your disposal is to wollow out the holes with a fairly large drill bit, I'd say about 9-10mm and then use the dremel with thise grinding bits to finish it out since trying to use a hand drill to apply axial force to oval a hole is near impossible.
This takes a bit of time and effort, but well worth the simplicity and price range of many dsm turbo set ups.
Sidenote: The lower passenger side stud is too far from the flange to grab on so a large washer is needed to at least utilize that stud for some clamping force.
Since the ports are slightly oversize dont sweat it if you feel that your drilling job isnt 100% on center. For this reason the manifold is somewhat forgiving
Carbonaccord is offline   Reply With Quote
Old 08-10-2017, 03:19 AM   #2
apalileo
apalileo is cool... so far.
I've seen the FP DSM race manifold and it's very well designed. I'm also surprised given the number of turbo F22A's using the OEM DSM manifold that this one hasn't been tried before.
Props for your pioneering!
1993 Accord DX | Rosewood Brown Metallic
www.anthonypalileo.com
www.anthonypalileo.com/watches (secret link)
apalileo is offline   Reply With Quote
Old 08-10-2017, 03:45 AM   #3
H311RA151N
Silver Member
Considering the price of a new replacement OE turbo manifold the Forced Performance race turbo manifold is the way to go.
The FP Race turbo manifold goes for $275.00 directly from Forced Performance. A new factory OE is typically only about $20 cheaper.
The material is called D5S Ni-Resist. Which contains 36% nickel, 5% Silicon and 2% Chromium.
The maximum manifold temperatures for D5S is also quite high for a manifold of it's type. 1598*F for the manifold with 1742*F for the exhaust gas temperature. 870*C and 950*C. And D5S is fairly easily machined.
The FP Race turbo manifold is also noticeably heaver as it weighs 15 lbs give or take. Factory DSM turbo manifolds weight about 10-12.
Forced Performance will port it for you for $95.00 and coat it for $120 and their coatings are done by Tirado.
I myself wondered why more people weren't using this turbo manifolds on their F22A DSM set ups. I figured it was because they were either unaware or they were picking up used factory manifolds on the cheap.
Originally Posted by gloryaccordy View Post
Holy fuck, it's the weekend man.
Old 08-10-2017, 12:54 PM   #4
Carbonaccord
Some great info you got there! Blew me away lol.. yeah i never understood why nobody ever went FP manifold.. they're a little pricey over an oem but so much better in many aspects. I'll get some photos working soon i promise! Ive been trying from my s6 wich i feel is the problem.
Edit: oh and shipping weight was 12lbs according to ups. So id say theyre dang close in weight
Old 08-10-2017, 11:59 PM   #5
H311RA151N
Silver Member
I see you are running a TDo5. What wastegate is that pictured?
I'm glad you shared this information btw. You seem to be doing some pioneering as apalileo stated.
Old 08-11-2017, 05:06 PM   #6
deevergote
Don't call me dude.
I've never heard of this thing. I have a feeling many CB7 guys also aren't in the know unless they have DSM experience as well. It doesn't look all that impressive at first glance (though now that I see what it is, I'm impressed.)
I think it's also largely overlooked because 1) CB7 guys doing the DSM setup are usually trying to do the cheapest build possible. A $25 used DSM manifold that seems to be in good shape is what they're looking for. If they want to spend money, they probably go to Treadstone for a complete kit. Or 2) A shiny tubular stainless steel manifold that is made for the engine they're installing it on is likely what many people look for if they're doing something other than a stock DSM manifold. Any sort of performance-oriented manifold designed for the 4G63 is usually ignored because why buy something you have to modify when you can just buy something that is made to bolt right on!
That being said, this is probably a better option than damn near everything available for the F22A. If I was going to boost an F22A, a Treadstone kit would probably be my first choice... largely for the simplicity of getting a quality kit all in one shot... but this manifold is definitely intriguing!
Old 08-11-2017, 07:22 PM   #7
apalileo
You're right on the money deevergote. I would not have known about Forced Performance had I not owned a Subaru.
Old 08-11-2017, 08:09 PM   #8
H311RA151N
Silver Member
^^^ Wow, yeah. It's surely one of the most popular turbo manifolds in the DSM world. But it's cool that Carbonaccord seems to have brought it to attention though. The more options on the table the better.
Old 08-11-2017, 10:53 PM   #9
deevergote
Don't call me dude.
Absolutely. Especially since anything quality that may have existed for the f22 specifically is probably out of production, or soon to be.
Old 08-21-2017, 03:36 AM   #10
Carbonaccord
Hey no problem. Ive never ever touched a dsm in my life btw. I learn all about them through hours and hours of searching to get a nice retrofit set up going. Im not sure what wastegate it is (actuator i assume you asked about) but its an aftermarket unit with a 13psi spring and supposedly has farther throw than stock. My td05h has a ported wastegate and compressor outlet. Im actually going to get rid of it here soon! because 370 crankhp isn't enough for the supporting parts i have invested here. Im going with another td05h (clearance issues), but with a compressor cover thats machined for a 20g wheel (going billet 6 or 7 blade extended tip). And a 9 blade td05h turbine with 7cm ported exhaust housing and a stainless o2 housing with external wastegate and 3inch vband
Old 08-21-2017, 03:40 AM   #11
Carbonaccord
Thank ya sir! And Surprisingly I have zero dsm experience.. All the snooping around ive done over at dsm tuners has helped tremendously though lol which is why i knew about this manifold
Old 08-21-2017, 11:53 AM   #12
H311RA151N
Silver Member
Yeah the actuator arm is adjustable on that one. But I've never seen that exact one before. The OEM replacement for the 14b/16g is like $195. And of course I need one which is why I asked.
Old 05-07-2018, 07:51 PM   #13
99integraf22
99integraf22 is cool... so far.
Can you give me more info on this i was gonna try a 20g with dsm manifold on my f22 but i was wondering about fitment issues
99integraf22 is offline   Reply With Quote
Old 05-09-2018, 12:40 AM   #14
92smokeaccord
92smokeaccord seems to have made some friends! 92smokeaccord seems to have made some friends!
Like deev said, we only use the Dsm setup for a extreamly cost effective turbo setup.. also most Accord/dsm guys stop at a 16g turbo. There’s really no benifeit in a manifold upgrade for these dsm turbos. Anything asfter that they always jump to t3/t4 and get a full stainless. It’s actually more cost effective to go t3/t4 then it is to get a 20g and good manifold also less hassle. Good find tho
my new turbo build
92smokeaccord is offline   Reply With Quote
Old 05-09-2018, 12:42 AM   #15
92smokeaccord
The 20g will not fit with a dsm manifold on our cars. The block needs to be ground away to much cause the manifold is to “short”.
my new turbo build
Old 05-13-2018, 12:23 PM   #16
judonoh
judonoh is cool... so far.
I have had my FP manifold setup for about 9 years. The manifold is extremely well made with more than enough metal at the flange. Setup all depends on how creative you wish to get.
judonoh is offline   Reply With Quote
14b , 16g , dsm , fpmanifold , turbo
