Old 10-12-2017, 12:26 PM   #1
CarbonFibreGuy
CarbonFibreGuy is cool... so far.
New lighting setup help wanted.
Hry all. I'm interested in purchasing and installing Morimotos' LED retrofit set to put into my low beam bowls, but when it comes to the high beam bowls, could I use them to house typical, non projector DRL bulbs in them instead? They'll be wired to their own switch, likely an automatic light sensor.
I'm concerned about blinding people during the day, so are there any DRL specific bulbs I can toss in there? Advice would be appreciated.
CarbonFibreGuy is offline   Reply With Quote
Old 10-12-2017, 01:57 PM   #2
sonikaccord
Bulbs are bulbs. As long as you aren't running 65+ watt bulbs for DRLs, you won't blind anyone in broad daylight.
I'm assuming you're running bi-xenon (LED in your case) projectors in the low beam housing?
Edut: Four Thousand Posts!
Old 10-12-2017, 03:00 PM   #3
CarbonFibreGuy
Yep, not going to run high powered bulbs in the high beam bowls for that reason. Just wasn't sure if there was a specific wattage or bulb that people were running for this purpose already. I'm looking for a bulb that'll fit in the OEM socket so I don't have to tear or drill into it.
And yes, the LED projectors will be run in the low beam housing, or so far is the plan. I'm waiting to replace some other parts before I buy the lighting kit and go through with it. Maybe this is more suited as a members' ride thread?
And congrats!
Old 10-12-2017, 04:30 PM   #4
sonikaccord
You could run the OEM high beam bulb and a resistor in line...I have actually have some 4 and 2 ohm 50W resistors laying around if you want to see the brightness difference. I could also just do the math, but seeing is believing in this case.
The OEM bulb is about 3-4 ohms IIRC. A 4 ohm resistor would cut the bulbs power in half and a 2 ohm resistor would cause the bulb to see 75% power.
Old 10-12-2017, 11:36 PM   #5
djALBINI
djALBINI is cool... so far.
Just got the Morimoto H1 HID conversion kit with the 35W ballast setup for myself and plan on running that inside the JDM one piece headlight when the parking lights come on. A buddy of mine told me that setup will resemble the looks of a type R.
If it ain't a type R it ain't a tight car...
djALBINI is offline   Reply With Quote
Old 10-15-2017, 07:36 AM   #6
EG9
EG9 is cool... so far.
Post some pics once your done with them.
EG9 is offline   Reply With Quote
Old 10-15-2017, 06:45 PM   #7
gloryaccordy
I think you can get an OEM DRL module from a newer car. That will do the trick
