Old 12-19-2019, 07:41 PM   #1
zedjr10
Gold Member
zedjr10 may have said something they shouldn't have...
Would yall use HondaBond Ht for a tranny gasket on a subaru?
I am flushing adn draining the cvt fluid on a 14 impreza. Subaru doesn't use gaskets for their tranny pan so i have to make my own. WOuld yall use HondaBond HT. Or would something else be better?
zedjr10 is offline   Reply With Quote
Old 12-19-2019, 08:15 PM   #2
PhatAccord
CB7tuner Member
PhatAccord is cool... so far.
Send a message via AIM to PhatAccord
If it is a gasket-less pan; then yes. Honda bond is a great sealant. Just make sure you clean both surfaces and make sure it’s cured before you fill in the fluid.
I heard even the Toyota guys use Honda bond.
PhatAccord is offline   Reply With Quote
Old 12-19-2019, 08:56 PM   #3
fleetw00d
Contributing Member
I'm just curious, what does Subaru specify for the tranny? Planning to use Hondabond just because you already have some?
__________________
I'm down to one CB, going through withdrawal DTs
90 LX 4dr 5 spd 384,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 189,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
INVENTORY REDUCTION! LOTS of CB7 parts - you need it? you can have it. http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 12-20-2019, 02:47 AM   #4
zedjr10
Gold Member
Quote:
yes i was but then I went and got some permatex ultra grey. This tranny pan has no gasket. YOu must make your own. Subaru specifies their own stuff or something equivalent. Hondabond is so thick i remember.
Old 12-20-2019, 08:09 PM   #5
sonikaccord
Contributing Member
sonikaccord seems to have made some friends!
I thought Permatex Grey and Hondabond HT were similar. I've never used Hondabond before so no first hand experience.
__________________
YouTube Clicky!!
sonikaccord is offline   Reply With Quote
Old 12-20-2019, 10:12 PM   #6
fleetw00d
Contributing Member
Without digging out my manual, I believe Honda only specifies Hondabond for the split line of our transmissions, so I'm pretty sure it would work for Subaru.
