Easy Rust Repair
    Easy Rust Repair
    Found a video specially for us (no promo)
    http://youtu.be/-pouJ9Y5_hw
    I love how they blur the H...
    That's really just for fixing surface rust, though. Our major problem is with rear quarter panel rust, which is almost always a hole straight through the metal. Bondo won't fix that (and I've seen countless people try!)
      Thats tight how dude taped off the grill... Just remove it, playboy.
          I used Bondo to repair a hole through the quarter panel. I did that about 2 years ago and it has held up fairly well. To repair larger holes, a metal mesh backing is really needed to support the Bondo filler.
            Rust sucks... I have a small speckle on my rear quarter... Gonna look for a way to fix it...
              You didn't fix it, you just covered it up.
                I would like to fix mines, but unsure of cost
                  Not too expensive, and the best part is that you learn how to do it.
                  Maybe $10 on sandpaper, like $20 of paint (the exact number, and a good clear) $20 on bondo, if you have the equipment the job is done on $60 bucks or less. If not, there's a good arm exercise, or add to that number $50 more. But it's recommendable to have equipment for at least remove the rust. If it's a hell of a hole be careful how you do it.
                  Or spend $200 or $300 on a shop for a proffessional job .
                    To properly fix it involves cutting and welding....not bondo.
                    1991 Cappuccino Brown LX Coupe
                    2013 Rallye Red Civic EX Coupe
                      I love how they use a white car to hide the terrible clearcoat blend line you will have. And not only that but that car is going to be covered in overspray! He could have just backmasked the hood and used a few pieces of paper to cover the light and grill. Instead he decided to use a shitload of tape which will take longer and be more expensive haha
                        this is cool..
                        but its not gonna get rid.of.the rust..only cover it....
                        do it right.the first time .
                        [COLOR=DarkRed][B]I LIVE ACCORDINGLY * 93 CB7
                          Replace would be my choice, everthing but the rear quarter panels should be replaced when it gets cancer.
                          Rear quarter panels can be cut and replaced as well but it is a bit more involved.
                          I dig the 90-91 CB7 in the video, we all know there is a H under that big blur.
