Clock Question
    Clock Question
    I was wondering, If I was to put the cb7 clock in an diferrent application what would i need to know about it.
    I know that it needs constant power to keep correct time and it seems indpendent of the dimmer but what else do I need to know anout the wires?
    I am doing a project of sorts and deemed the clock a Goat to the rock slab to be bleed to the electronic Gods.
    Thanks for any info!!!!
    S^2
    Running a 16yr old wagon and still loving it.
    The clock has 4 wires. +12v constant, +12v switched, illumination, and ground. I'm not exactly sure where they are on the plug, so I can't help you with that.
    I can tell you though that the +12 constant keeps the time with the display off, the +12 switched turns the display on, and when +12 is put onto the illumination the clock will dim.
      clock relocation?
      where are you going to put the clock at and what are you doing?
      What Do You Tell a Chick With 2 Black Eye's?
      Nothing You Already Told Her Twice
        I plan on using it for an art setup using left over parts for a project. I have the DC taken care of for power, Just needing the wire layout.
        I cannot find my manual as of right now and this site is the closest thing to it,
        Better actually.
        T.I.A.
        S^2
          It actually has a diagram on the clock if you have a JHM clock,
