Bisimoto stage 1 cam
    92 Accord Coupe EX, stock F22a6, 245k miles.
    I want to get the bisimoto cam stage 1 regrind, and get it tuned.
    Should I get the springs with stage 1? What ecu do I want, and where should I get it? Will I be able to drive to a tuner with the new ecu?
    You don't have to get the Bisi Pro Springs with the Lvl 1, but it's still advised.
    You want a chippable ECU.
    You need a basemap to drive safely to a tuner.
      I know nothing about ECUs. I just want to know which model number would be best, where to find it, and how to put a basemap on it.
        P06, P28 , and P72 are some of the more popular ecus that can be chipped. A p06 will probably be the cheapest and you can find any of these at a junk yard, ebay, craigslist, etc. A few members like d112crzy and I think MRX can provide you with a basemap or you could find a local tuner.
        ^^^^CLICK IT^^^^^
          You do not need upgraded springs for the bisi stage1.
          If you have the PT6 ecu, it will most likely run the stage1 cam ok to get to a tuner if it's a short distance, then swap over to the p06 and tune it. You should verify this with a tuner though (such as d112crzy or MRX).
          My Member's Ride Thread
