Hello everyone, i just joined today and wanted to say hello and give yall a look at my car. I have a 1992 Honda Accord LX automatic. Its not quite as decked out as some ive seen but i love the heck out of it. My car before was an old blazer, and i was worried about the change to a honda, but this car is just so fun to drive. I painted the rims with plasti-dip, except for one cause i got lazy. I have a lot of plans for it in the future, when i get it running again at least. Ill get some more pics when i do fix it, which should be just a few days from now.
New member, wanting to share my car
Originally posted by H311RA151N View PostI look forward to your progress! What are your immediate plans?
well, i have to replace the thermostat on thursday so i cAn drive it lol. But i plan on painting that other rim. Then i'm working on replacing the exhaust manifold and the air intake. Im not the most mechanically savvy person out there, but im pretty good at figuring stuff out, and ive gotten used to changing out parts on it.
Back in january my alternator, battery, exhaust manifold, and thermostat all went in the same morning, been trying to recover from that.
Well, you came to the right place.
As for the thermostat, I recommend an OE temp not an alternate. Be sure to change the rubber gasket/o-ring. Also, with these cars you cannot simply add coolant. There is a 12mm bleeder valve on top of the thermostat housing, open it a turn or turn and a half after completing the thermostat change and before replacing lost coolant. Start adding coolant and watch the nipple on that valve, once it starts running solid coolant from it and is done spitting the air out, close it and then finish filling the radiator.
What happened to your exhaust manifold?
The manifold had a small crack in it, then on that morning i noticed it was quite a large crack and it was leaking and making steam. i patched it and its doing good for now, but i want it replaced.
Originally posted by H311RA151N View PostI hear ya. You can find another F22A1 exhaust manifold pretty easily. Or, you could weld your current one up and it would be just as good. As long as it doesn't leak your in business.
