Old 11-13-2017, 05:30 PM   #1
nuss
nuss is cool... so far.
exhaust pipe repair, broken flange.
Hi all,
My exhaust has broken by the flange at the rear of the car, not far from the muffler.
The submitted picture can be viewed at original size at https://i.imgur.com/9woTiAH.jpg
Does anyone have a suggestion on a suitable repair?
Right now I just want it to work. It would be nice if it could last a couple of years.
I was thinking of putting a split flange repair kit there but I do not know about vibrations and the springs and bolts that could be necessary.
It is a Honda accord -91 with a f22a3 engine.
nuss is offline   Reply With Quote
Old 11-13-2017, 07:11 PM   #2
F22Chris
Weld it?
If thatís not an option, cut the flange off completely, and run a pipe that will fit over the existing exhaust & secure it with some exhaust clamps.
Old 11-14-2017, 12:57 AM   #3
CB7_Saloon
CB7_Saloon is cool... so far.
It shouldnt cost that much to go to your local jy and pick one up yourself. Pick N Pull posts their prices online if youre near one of those.
CB7_Saloon is offline   Reply With Quote
Old 11-16-2017, 12:08 AM   #4
Ghostwhite
Ghostwhite is cool... so far.
The only good way to reuse the original flange and pipe would be welding it back up.
F22Chris's idea of going without the flange would work as well, remove the flange from both pipes and bridge the gap with another section of pipe and clamp it.
Ghostwhite is offline   Reply With Quote
broken , exhaust , flange
