Go Back   CB7Tuner Forums > Site Features > DIYs > Suspension DIYs
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 12-21-2009, 10:26 AM   #41
da9b16
Contributing Member
da9b16 is cool... so far.
Send a message via AIM to da9b16 Send a message via Yahoo to da9b16
Quote:
Originally Posted by civic_90_08 View Post
Bump this thread.
Im in for info about the axles and the rear end parts.
Im disc in the rear...just need to know what parts are needed for the rear end.
Let me re- phrase what I have already stated.... the CRV rear end trailing arms will work on ONLY civic and Integras since they are similar chassis. The CRV rear end AWD will NOT work on accord as they have completely DIFFERENT rear ends....
The only ONLY parts you can use are the outter drum.... not the whole assembly.....
The 97-99 TL 5 lug CAN be used but you have the change the hub to the LUDE hub because the TL hub sits out further creating an offset if you will that sticks out almost 1" from the fender... anything else?
__________________
WAGONS
94 ce1- f22b DOHC auto swap, ROH 11.1" 99 cl brakes, rear disk swap, dual plenums, aem cai, tein ss, OEM stanley one piecers, OEM stanley yellow fogs, OEM 96 Oddy roof rack, Yakima basketcase, some wheels, some tires.... etc.
da9b16 is offline   Reply With Quote
Old 12-21-2009, 11:31 AM   #42
civic_90_08
CB7tuner Member
civic_90_08 is cool... so far.
Send a message via AIM to civic_90_08 Send a message via Yahoo to civic_90_08
thanks for clearing that up.
__________________
I ♥/Miss My Coupe
civic_90_08 is offline   Reply With Quote
Old 12-23-2009, 12:07 AM   #43
bobbycos
Contributing Member
bobbycos seems to have made some friends! bobbycos seems to have made some friends!
Send a message via AIM to bobbycos
what do you mean any more info???
what i actually wanted ask was , if you can use stock F22 auto axles on the swap. (i needed a way to not forget where this thread was)
i want to do the swap but will stay stock motor/trans for a while
bobbycos is offline   Reply With Quote
Old 12-23-2009, 10:19 AM   #44
da9b16
Contributing Member
Yes indeed you can use the accord axles...... Since my h22 is using accord axles and they have the same spline count as these do.
I want to say this again for clarity..... you will have to have the tow corrected once this is done.... since the mounting point is closer to the hub. I did a redneck alignment on mine last night so that I could drive it.....
__________________
WAGONS
Old 12-25-2009, 11:37 PM   #45
bobbycos
Contributing Member
thank you a million times over !!!
Old 12-25-2009, 11:51 PM   #46
da9b16
Contributing Member
I am in the process of verifying a few final details but you are welcome. I hope to show some more updates soon to this process. I may end up going back to rear disc after all. I love the drums cause they are easier but I am thinking of boosting and have rear disc already that are 5 lug just need to decide on stopping force.
__________________
WAGONS
Old 12-25-2009, 11:59 PM   #47
noobcake
Contributing Member
noobcake seems to have made some friends!
gooood shit bro.
im glad somone found an easier way
noobcake is offline   Reply With Quote
Old 12-26-2009, 08:48 AM   #48
bobbycos
Contributing Member
one more thing about the front knuckles. i read the post stating they have to have the S5 stamp on them but do they have to be from the 2000 model year or can I get them from a 99 or 01 Ex V6
Old 12-26-2009, 10:14 AM   #49
jhoff
CB7tuner Member
jhoff is cool... so far.
accord and cl v6 models the same?
jhoff is offline   Reply With Quote
Old 12-26-2009, 10:20 AM   #50
da9b16
Contributing Member
Quote:
Originally Posted by bobbycos View Post
one more thing about the front knuckles. i read the post stating they have to have the S5 stamp on them but do they have to be from the 2000 model year or can I get them from a 98 or 99 Ex V6
I have NOT been able to find any 99-00 that are stamped with the s5 on the back that were NOT 00-01. In other words if you can find them and verify that they have that stamp or that you can shove an f22/h22/h23 axle in em then go for it.... I just never found one.
__________________
WAGONS
Old 12-26-2009, 10:21 AM   #51
da9b16
Contributing Member
Quote:
I have not been able to verify this either. I have a new job now working for At&t and I don't have as much free time.
__________________
WAGONS
Old 12-26-2009, 10:23 AM   #52
jhoff
CB7tuner Member
this is what its telling me
Quote:
ACCORD 98-02 6 cyl
CL 01-03 (3.2L, 6 cyl)
TL 99-03 (3.2L, 6 cyl)
Old 12-26-2009, 02:01 PM   #53
da9b16
Contributing Member
You can try it but I can tell you again that the 98-99 are different than the 00-02.... The chasis code even changes on the one with the S5 stamp. The reason this option was never explored is due to the difference in the year models. There is a smaller 32mm nut on the 98-99 version. I have indeed verified this on several different cars and body types.
__________________
WAGONS
Old 12-29-2009, 10:19 AM   #54
bobbycos
Contributing Member
bump this thread
calling a few j/y's today to get the front knuckles and gonna specify 2000 accord ex v6 ONLY , will get prices for the NY rea
Old 12-30-2009, 08:00 AM   #55
da9b16
Contributing Member
bump this thread
To make sure you get the correct ones I verified the chasis is a CG and just make sure on the dust cover you see stamped S5. This for sure is f22/23/h2223 axle friendly.
__________________
WAGONS
Old 01-01-2010, 12:30 AM   #56
bobbycos
Contributing Member
got a set of spindles from an 02 TL that were stamped K6. I went to my part-time job (KMB Auto Parts Warehouse) and grabbed an axle for 90 Accord. It fit the spindle. I printed the pics from the post to match up as best I could.
Apparently no j/y's around here have any 00-01 Accord EX's.
Before I forget I got a part number for the rear Lude hubs if you want new
BCA/Timken 512144
Old 01-01-2010, 11:38 PM   #57
bobbycos
Contributing Member
bump
Old 01-16-2010, 04:43 AM   #58
rezist09
CB7tuner Member
rezist09 is cool... so far.
i got lost with the rear so front all i need is the 97-00 front and rear? hmm might do this looks cheap
__________________
1992 Accord Cb7:
rezist09 is offline   Reply With Quote
Old 01-16-2010, 07:40 AM   #59
bobbycos
Contributing Member
Quote:
the rear is basically 16 parts involved
2 prelude rear hubs
2 crv rear drums
2 5 lug rims of your choice
10 lug nuts
that is all
as for the front use 2000 up to be safe
Old 01-19-2010, 06:47 PM   #60
HybridKyle
CB7tuner Member
HybridKyle is cool... so far.
Bump for Wagon fitment info
__________________
*Click on photo for my MR thread
HybridKyle is offline   Reply With Quote
