Here is a bit of a noob question, when changing the dead on a f22 engine, either to upgrade or replace the old one, do i have to resurface the head and or block if there wasnt an overheat?
Replacing head, do i need to resurface?
Originally posted by Rat View PostHere is a bit of a noob question, when changing the dead on a f22 engine, either to upgrade or replace the old one, do i have to resurface the head and or block if there wasnt an overheat?
from Helms
*If warpage is less than 0.05 mm (0.002 inches) cylinder head resurfacing not required
*if warpage is between 0.05 mm (0,002 inches) and 0.2 mm (0.008 inches) resurface cylinder head
*Maximum resurface limit is 0.2 mm (0.008 inches) based on a height of 100 mm (3.94 inches)
You would measure from corner to corner of the locating pins ( criss cross, short length and long length) and use a feeler gauge to determine clearance between the head and a straight edge held across these measuring points
Originally posted by Rat View PostThat pricing isn't bad at all. What about the block itself? Does anything need to be done to it? In my case I am fixing a bent valve (timing belt broke) so I have to take the head apart to do it.
Measure diagonally across, front to back and side to side. You'll need a precision straight edge as any warp in the straight edge will add inaccuracy to your measurements and given the small degree of warpage needed to be beyond service limit you need to be accurate in your measurements.
