I recently swapped my a1 tcu for an a6 tcu I found at the JY..3 wks later I'm keep getting a flashing d4 light? Should I switch back to my a1 ecu?
A6 tcu causing flashing d4?
Originally posted by cloudasc View PostTry pulling the codes for the d4 issue and report back. You can also open it up and look for burned components or leaking capacitors (tcu), if you find any you can switch back to your a1 tcu and be fine, otherwise read the diy tcu fix in my signature.
