I'm sure it is somewhere on the forum, but couldn't find it. Just bought a dx without rear sway bar. Want to install one from my previous cb. Does rear crossmember has holes for mounting brackets for this bar? Or must I replace crossmember also?
DX rear sway bar
Originally posted by cb3frompoland View PostI'm sure it is somewhere on the forum, but couldn't find it. Just bought a dx without rear sway bar. Want to install one from my previous cb. Does rear crossmember has holes for mounting brackets for this bar? Or must I replace crossmember also?Originally posted by DKR977 View PostI'm fairly sure that you will need a crossmember from an EX and a EX sway bar as well unless you go with an aftermarket swaybar kit.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Aren't the mount holes also missing from the swing arms?1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by wildBill83 View PostAren't the mount holes also missing from the swing arms?
You drilled holes because you had an adjustable one. The holes for the OEM sway bars do exist on the DX/LX trailing arms, though.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Jarrett is correct, while I was out messing with the LX I saw the holes. I was just coming back to say they were there.1993 SE Coupe MRT - 1992 LX Sedan MRT
